Also, if you select "Knowledge base" from the menu on the left side of the screen, and inscribe "wireless drivers", you'll get some additional clues.
Which website? Try this (and the software pre-installed) at
VAIO Support Agent
Access to the Sony VAIO Support Agent comes with each VAIO computer and will provide you with 24 hour access to a program to diagnose and fix software problems, VAIO FAQs, and the online VAIO support central resources.
.... Web Resources
For product support, drivers, software updates, news and questions about your VAIO PC, visit our North American support database online at:
I may not be in the right place, but I have one of these notebooks with wireless lan and I have no idea where to find the driver for it. The Sony web site was not any help. Anyone else have one of these that could possibly lend a hand? Thanks.
It should be on your system restore disk that came with the laptop......
I have no discs, it was an open box display.
Then call Sony's customer support and request a set of restore disks. It will cost about 20.00 dollars or so and will be invaluable in the future to you since it will come with the complete system setup and OS.
