This new "MIMO" wireless card is supposed to work with 98SE. The card appears to install, and "The device is working properly" is displayed in Device Manager, no exclamation points. However, the Netgear WPN311 Wireless Assistant configuration utility will not start. The hourglass runs for a few seconds, then stops without a window opening and without an error message.
System is a Soyo K7VTA Pro with Athlon XP1800+, 256 MB ram, and plenty of hard disk space. The system has no viruses or spyware and runs well. If I use a standard NIC and ethernet cable, Internet access works fine.
To test the card, I tried it in an XP Pro system. It installed and worked perfectly, so the problem is not the card itself.
In my attempts to get the card to work on the 98SE system, I tried removing all the other PCI cards, removing both the Netgear card & software and reinstalling, using several different PCI slots, using the driver downloaded from Netgear instead of the driver on their, installing in safe mode, running in safe mode, stopping everything else from loading using msconfig.
I spent about an hour with Netgear's "HELP ME LEARN ENGLISH! (TM)" tech support. By the end I think that my student learned the meaning of "gigahertz," but I could easily be wrong about that. One of her more interesting suggestions was that I change CPUs, because the installation utility or the drivers might not be compatible with the Athlon XP. Right.
Any suggestions welcome.
