bt seem to think not even though i suspect otherwise - here is the problem:
i have a win2k pro machine it is up to date - it has mcafee and zone alarm installed
using a bt voyager 1055 wireless adapter and bt voyager 2091 wireless router i try to connect - the connection remains for a minute then drops
i have tried with and without the antivirus and firewall software running and still the same
now i tried to see if it was a problem with the configuration:
i installed winxp pro on a spare partition - lo and behold it works perfectly (that's how i am sending this!) - however i can't use xp pro because i dont have a licence and i don't see why i should pay more money when 2k pro is meant to run wireless fine
is there something extra to be done in 2k?
is there any software that will 'help' 2k pro run wireless as simply as win xp pro?
any help would be greatly appreciated
many thanks
martin
