Hi Guys
Im hoping you guys can give me some guidance with regards to x10 as im not too familiar with using it...I use CBUS for lighting but would like to be able to use some x10 plugin modules here and there as they are much much cheaper than using the CBUS wireless kit.........
I got one of Jeffs XTB II devices (in kit form) a while back and had a play with it connected to my Homevision controller....I did have some issues with it but was too busy with work to spend time on it....
Now that i have a few days off i thought i would try and get the x10 stuff working but this time round i couldnt get any on the plugin modules to respond at all ;-( .......I can however control an LD11 which has a lamp connected to it and have placed it in several locations around my small house and it responds fine...I have tried setting up a lamp module with the same id as the LD11 and plugged into the same power strip as the LD11 but it doesnt respond ......any ideas ????
Also i was considering purchasing the elk esm1 and was hoping that i can convert it to 240v by replacing the plug pak ...???? 50hz ????
Thanks Frank
