RC-80B Thermostat Issue!
Threaded View
All,
I have 2 RC-80B Stats connected to an HAI Omni-Pro II controller. Both
thermostats have worked correctly since installation in June '05. However,
one of my thermostats no longer reports current room temperature to the
controller... it reports "0" as the temperature. All other functions on this
thermostat seem to work, including remote operation.
Lastly, the thermostat's local display shows the correct room temp.
Any advice or suggestions would be greatly appreciated!!!
Regards,
Tony
Re: RC-80B Thermostat Issue! Fixed...
Sorry folks... I found the problem. It was a broken lead inside the Omni
cabinet affecting the received signals from the stat...
"It always pays to check things twice!"
Regards
Tony
Site Timeline
