I have been searching hard for a reference or discussion for what I want to do, but so far no luck and I am still puzzled. I hope someone here will steer me right.
I want to install up to 4 CCTV cameras for home security. Running cable is no problem (I have already run a cable package that includes 18-4/Cat5e/RG-6 Quad to each location). I do not require VCR capability or alarm tie-in just now.
I presently have a ChannelPlus DA-8200-BID distro amplifier feeding the video network from a central control panel. The "B" mod port is used for a ChannelPlus 4 port modulator from the media room. I want to use the ChannelPlus "A" mod port for the CCTV cameras.
Question: Is there a "box" into which I can feed the 4 camera leads, and from which I can feed the ChannelPlus "A" port, so that I can view the CCTV camera output on any display device on the network? Is a standard multiplexer sufficient?
