Hi there,
I have 3 LANs that are totally separate from each other. It's very important that data must not be routed from one LAN to another. The LANs have different network addresses.
What I need to do is to have a PC that has access to ALL of the LANs simultaneously. What I'm thinking of doing is to introduce a PC that had 3 NICs installed, each of the NICs connected to each of the LANs.
Physical access to the PC with the multiple NICs would be restricted, and the system would not be connected to the internet; it's sole purpose would be to access specific mainframe systems on each of the local area networks by use of terminal emulator software.
Is there any need for the use of a firewall in this situation- the PC wouldn't route data. I realise that a firewall would be preferable in this situation, but I dont really see the need if the data cannot route between networks.
Before anyone shouts at me, I understand that I must adhere to a solution that is satisfactory and that's why I'm asking the question here. Please advise what would be the most secure solution. Advice on a good secure software firewall that would be of use in this situation would be most useful.
Thanks in advance of any contributions, advice or comments. Hoastey
