DHCP Question
Threaded View
I'm expanding a DHCP IP Scope by changing the subnet mask on a class A network from /27 to /26.  What are the important risks that I need to asses on my switches and routers to make sure this implementation goes well?
Re: DHCP Question
maximus_max wrote:
 Offhand, change the addressing on the affected interfaces to match and, if
you are advertising the subnets in routing protocols using network
statements or a route-map, check those as well.
Site Timeline
