Now with pictures!
Subject
- Posted on
- Stuart Wilcox
May 8, 2005, 10:44 pm
Hi, I'm playing around with OSPF, trying to get a grip of it. I've come
across an issue I don't understand. I've got the following config.
router ospf 1
log-adjacency-changes
redistribute static metric 10 subnets
network 10.5.0.6 0.0.0.0 area 0
network 10.5.3.1 0.0.0.0 area 0
ip route 0.0.0.0 0.0.0.0 Dialer2
ip route 83.5.211.5 255.255.255.255 Dialer2
in a neighbouring table the default route is missing...
84.0.0.0/32 is subnetted, 1 subnets
O E2 83.5.211.5 [110/10] via 10.5.0.6, 00:07:07, Serial0
10.0.0.0/8 is variably subnetted, 5 subnets, 3 masks
C 10.5.0.4/30 is directly connected, Serial0
O 10.5.3.0/24 [110/161] via 10.5.0.6, 00:07:08, Serial0
C 10.5.2.0/24 is directly connected, Loopback0
O 10.5.1.1/32 [110/65] via 10.5.0.1, 00:20:20, Serial1
C 10.5.0.0/30 is directly connected, Serial1
I would expect both those static routes to be propogated across the domain
as O E2 types, but only the bottom one of the two routes get passed on.
Could anyone explain to me why the default route doesn't?
thanks.
Re: why doesn't ospf redistribue default routers?
Source : "Cisco Cookbook" (O'Reilly)
You cannot create a default route in OSPF by simply redistributing a static
route as with RIP and EIGRP.
Even if there is a default route in the routing table, it will not be
forwarded by default. This is because OSPF uses link state algorithm that
keeps track of links rather than routes.
You must explicitely tell OSPF you want to source the default route with the
"default-information originate" command.
Therefore you may want to issue on the gateway:
(config)#router ospf 1
(config-router)#default-information originate metric 10
(config-router)#end
Bernard.
Site Timeline
- » why so few CCIE Voice certs?
- — Next thread in » Cisco Certification
- » Loading network-confg?
- — Previous thread in » Cisco Certification
- » digital printing|custom printed packaging |computerized cutting services.
- — Newest thread in » Cisco Certification
- » 'No Company Is So Important Its Existence Justifies Setting Up a Police State' &...
- — The site's Newest Thread. Posted in » General Telecommunications Forum
