ARP packets
Threaded View
Is it possible to limit or block ARP packets from going thru a catalyst
switch? Is there such a command or option? I've surfed the whole day
but no luck!
Re: ARP packets
I don't think there's a port no. for ARP, by which I can use an ACL to
filter it out.
Re: ARP packets
Jo wrote:
arp works at the Etherenet level.  So there are no ports to filter.
arp frames have 0x806 as the ethertype and that's about it.
Why would you want to break ethernet by blocking arp frames?
"Somehow I imagined this experience would be more rewarding" Calvin
**************************ROT13 MY ADDRESS*************************
Due to the volume of email that I receive, I may not not be able to
reply to emails sent to my account. Please post a followup instead.
Re: ARP packets
I'm being asked to lookup for info on how to limit or block ARP packets
on Catalyst 3550 or 3725 router as we're getting too many ARP requests.
It's believed that the network is under attack bcoz of a virus.
Re: ARP packets
What makes you think you are getting too many ARP requests? Have you
installed a sniffer on your network to see exactly what is happening?
Is it arp requests for a specific IP or random?
I guess if you wanted to filter arp frames on a layer 2 interface you
could use a mac based access-list something like the following
mac access-list extended ARP
    deny any any 0x806 0x0
    permit any any
interface <interface-id>
    mac access-group ARP in
If you wanted to filter on a complete VLAN if I'm not mistaken you
could use a VACL
    permit any any 0x806 0x0
vlan access-map ARP 10
    match mac address ARP
    action drop
vlan access-map ARP 20
    action forward
vlan filter ARP vlan-list <vlan>
Again not sure why you would want to do this as it would have serious
consequences for your network
Re: ARP packets says...
You could probably do that by using broadcast-storm option since ARP
packets are just broadcast. This will probably do some connectivity
problems to your network.
Why whould you want to limit/block ARP packets?
*** Use Rot13 to see my eMail address ***
Re: ARP packets
you might find the link below useful
or easily you may read thru.
 Command Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
interface interface
Enter interface configuration mode, and enter the port to configure.
Step 3
port storm-control broadcast [threshold {rising rising-number falling
Enter the rising and falling thresholds for broadcast packets.
Make sure the rising threshold is greater than the falling threshold.
Step 4
port storm-control trap
Generate an SNMP trap when the traffic on the port crosses the rising or
falling threshold.
Step 5
Return to privileged EXEC mode.
Step 6
show port storm-control [interface]
Verify your entries.
Site Timeline
