Will this setup do what I think it will?
Sep 30, 2007 6 Replies
Adair Winter
Put that box in client bridge and input your SSID and key for the router you want to connect to. ADair
Hi all,
I have a Linksys WRT54GL upstairs sharing the net and connecting various systems (PCs, Laptops, PDAs Wired and WiFi) for file sharing.
I want to convert a room into a PC workshop downstairs and will need net access. Can I buy a WRT54G (Preferring to keep all Linksys), flash it to
3rd party firmware and use it to recieve the wireless signal and pump it out via the 4 LAN ports on the back?
I'm asking about this scenario as I don't feel I want to go drilling holes in an asbestos-filled ceiling!
Thanks,
Tesla
Yes, but buy another WRT54GL and flash DD-WRT to it. Put that box in client bridge and input your SSID and key for the router you want to connect to.
ADair
What is wrong with your current setup? Can you not receive a wireless signal from the upstairs wireless router? If so and unless I missed something, your current setup *should* do what you want.
Ah yes, that's one thing I forgot to mention. I will be re-locating a server down to this room and will have up to 2 engineer PCs in the same room. As it will be a PC workshop, it will mean I will have other PCs in the room that are not mine and so would a) not want to have to buy wiresless adapters for each system and b) if the systems I am wokring on are not mine which is nearly 100% likely, I would preffer not to have to install adapters in them just to get net access.
Thanks for the replies so far :-)
Yes. You can get another WRT54G and flash DD-WRT (3rd party firmware). This will give you the ability to turn the new router into a wireless bridge with the 4-port capability. Visit
for info. I just did this with my v5 WRT54G router using the micro version of DD-wrt.
On 2007-09-30, Tesla intrigued me by typing:
Oh, okay. I get the picture now (smile) and yes, an additional WRT54G will work in your setup with or without 3rd party firmware. Take care.
"Tesla" writes: (snip)
(snip)
It's easy to configure OpenWRT as a transparent wireless/wired bridge. Probably the other third-party ones too. You can also even use WDS to link wired networks wirelessly if that sort of thing appeals.
Yes, I'd be amazed if you couldn't do what you want here.
Mark
