WDS questions
Jan 27, 2006 1 Replies
New to WDS, so please bear with me...
  1. With two APs, are there any means by which I can tie a client to one AP rather than the other?
  1. What's the effect on WLAN throughput of adding a 3rd WDS AP? Does it half again?
If you have the APs connected via WDS then the client will use the stronger signal.
Yes.
