update: No IP assignment at TMobile hotspots
May 23, 2005 2 Replies
Recap: Laptop running Suse9.1Pro with Cisco Aironet 350 PCMCIA card. Associates fine with home (WEP'd) WLAN, and some friends' various (unWEP'd) WLANs, connects to internet flawlessly. Will not get IP from DHCP servers are public hotspots like Kinko's, Borders, Panera Bread, various hotels.
Well, I think I made a mistake, or gone backwards. Now I can't seem to get my card to associate with the Kinko's AP.
Here's what I get:
Omnicomm:/home/David # iwlist eth1 scanning eth1 Scan completed : Cell 01 - Address: 00:0E:83:B6:72:4E ESSID:"tmobile" Mode:Master Frequency:2.417GHz Quality:0/10 Signal level:-28 dBm Noise level:-256 dBm Encryption key:off Bit Rate:1Mb/s Bit Rate:2Mb/s Bit Rate:5.5Mb/s Bit Rate:11Mb/s
So far, so good. But then:
Omnicomm:/home/David # iwconfig eth1 ap tmobile Interface eth1 doesn't support IP addresses eth1 Interface doesn't support IP addresses Error for wireless request "Set AP Address" (8B14) : invalid argument "tmobile".
And here I'm stuck. I tried:
Omnicomm:/home/David # iwconfig eth1 essid tmobile Omnicomm:/home/David # iwconfig eth1 eth1 IEEE 802.11-DS ESSID:"tmobile" Nickname:"Omnicomm" Mode:Managed Frequency:2.442GHz Access Point: FF:FF:FF:FF:FF:FF Bit Rate:11Mb/s Tx-Power=20 dBm Sensitivity=0/65535 Retry limit:16 RTS thr:off Fragment thr:off Encryption key:****-****-** Security mode:open Power Management:off Link Quality:126/10 Signal level:-92 dBm Noise level:-97 dBm Rx invalid nwid:6 Rx invalid crypt:425 Rx invalid frag:0 Tx excessive retries:23 Invalid misc:4787 Missed beacon:0
But that obviously wasn't any good. Then I tried:
Omnicomm:/home/David # iwconfig eth1 ap 00:0E:83:B6:72:4E Omnicomm:/home/David # iwconfig eth1 eth1 IEEE 802.11-DS ESSID:"tmobile" Nickname:"Omnicomm" Mode:Managed Frequency:2.442GHz Access Point: FF:FF:FF:FF:FF:FF Bit Rate:11Mb/s Tx-Power=20 dBm Sensitivity=0/65535 Retry limit:16 RTS thr:off Fragment thr:off Encryption key:****-****-** Security mode:open Power Management:off Link Quality:126/10 Signal level:-92 dBm Noise level:-97 dBm Rx invalid nwid:8 Rx invalid crypt:425 Rx invalid frag:0 Tx excessive retries:23 Invalid misc:4916 Missed beacon:0
But even though I didn't get any error messages, nothing happened.
Relevant chunks from /var/log/messages:
May 23 15:20:10 Omnicomm cardmgr[2364]: socket 0: 350 Series Wireless LAN Adapter May 23 15:20:11 Omnicomm kernel: airo: cmd= 111 May 23 15:20:11 Omnicomm kernel: airo: status= 7f11 May 23 15:20:11 Omnicomm kernel: airo: Rsp0= 2 May 23 15:20:11 Omnicomm kernel: airo: Rsp1= 0 May 23 15:20:11 Omnicomm kernel: airo: Rsp2= 0 May 23 15:20:11 Omnicomm kernel: airo: Doing fast bap_reads May 23 15:20:11 Omnicomm kernel: airo: MAC enabled eth1 0:f:f8:4f:6a:23 May 23 15:20:11 Omnicomm kernel: eth1: index 0x05: Vcc 5.0, Vpp 5.0, irq 3, io 0x0100-0x013f May 23 15:20:12 Omnicomm kernel: Setting key 0 May 23 15:20:12 Omnicomm kernel: SFW2-OUT-IPv6_PROHIB IN= OUT=eth1 SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0001:ff4f:6a23 LEN=72 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=0 May 23 15:20:13 Omnicomm kernel: SFW2-OUT-IPv6_PROHIB IN= OUT=eth1 SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0001:ff4f:6a23 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=135 CODE=0 May 23 15:20:14 Omnicomm kernel: SFW2-OUT-IPv6_PROHIB IN= OUT=eth1 SRC=fe80:0000:0000:0000:020f:f8ff:fe4f:6a23 DST=ff02:0000:0000:0000:0000:0000:0000:0002 LEN=56 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=133 CODE=0 May 23 15:20:16 Omnicomm kernel: SFW2-OUT-IPv6_PROHIB IN= OUT=eth1 SRC=fe80:0000:0000:0000:020f:f8ff:fe4f:6a23 DST=ff02:0000:0000:0000:0000:0001:ff4f:6a23 LEN=72 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=0 May 23 15:20:16 Omnicomm ifup: No configuration found for wifi0 May 23 15:20:18 Omnicomm kernel: SFW2-OUT-IPv6_PROHIB IN= OUT=eth1 SRC=fe80:0000:0000:0000:020f:f8ff:fe4f:6a23 DST=ff02:0000:0000:0000:0000:0000:0000:0002 LEN=56 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=133 CODE=0 May 23 15:20:19 Omnicomm SuSEfirewall2: Firewall rules successfully set from /etc/sysconfig/SuSEfirewall2 May 23 15:20:22 Omnicomm kernel: SFW2-OUT-IPv6_PROHIB IN= OUT=eth1 SRC=fe80:0000:0000:0000:020f:f8ff:fe4f:6a23 DST=ff02:0000:0000:0000:0000:0000:0000:0002 LEN=56 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=133 CODE=0 May 23 15:20:23 Omnicomm kernel: eth1: no IPv6 routers present
One odd bit: Omnicomm:/home/David # iwconfig lo no wireless extensions.
sit0 no wireless extensions.
eth0 no wireless extensions.
eth1 IEEE 802.11-DS ESSID:"tmobile" Nickname:"Omnicomm" Mode:Managed Frequency:2.442GHz Access Point: FF:FF:FF:FF:FF:FF Bit Rate:11Mb/s Tx-Power=20 dBm Sensitivity=0/65535 Retry limit:16 RTS thr:off Fragment thr:off Encryption key:****-****-** Security mode:open Power Management:off Link Quality:126/10 Signal level:-92 dBm Noise level:-123 dBm Rx invalid nwid:16 Rx invalid crypt:425 Rx invalid frag:0 Tx excessive retries:23 Invalid misc:5141 Missed beacon:0
wifi0 IEEE 802.11-DS ESSID:"tmobile" Nickname:"Omnicomm" Mode:Managed Frequency:2.442GHz Access Point: FF:FF:FF:FF:FF:FF Bit Rate:11Mb/s Tx-Power=20 dBm Sensitivity=0/65535 Retry limit:16 RTS thr:off Fragment thr:off Encryption key:****-****-** Security mode:open Power Management:off Link Quality:126/10 Signal level:-92 dBm Noise level:-123 dBm Rx invalid nwid:16 Rx invalid crypt:425 Rx invalid frag:0 Tx excessive retries:23 Invalid misc:5141 Missed beacon:0
I don't know why, but wifi0 and eth1 are both the same connection. I usually just perform my commands on eth1, but trying them on wifi0 doesn't get me anywhere either. I'm stumped. I've used these same public hotspots, with this same hardware, before under WXP and had no trouble. What could be different between the various home WLANs and these public hotspots that's keeping me out? And why the *heck* would the Aironet card balk at taking an 'iwconfig ap' command? It makes no sense. If anything, I'd expect to have problems at *home,* because there I'm using WEP. I bought the Aironet precisely because it supposedly works natively with Linux w/o needing additional drivers. And at home, that's exactly how things have gone.
Okay, I made a big step forward: I had to use 'iwconfig eth1 enc off' to force the WEP off on the client end. As soon as I did that, the Aironet card associated to tmobile automatically, I even saw a MAC ID for the AP, and about 10-20sec later, eth1 got an IP from the DHCP server. Apparently, having just one WEP key set up under YAST causes the card to keep using that key, even when the YAST setting for AP and ESSID is "any," and the only AP within range is open. Now I just have to figure out why I can connect to my *friend's* open AP... gah.
But I can't get any internet traffic. Any attempt to ping the nameserver IPs gave consistent "Destination Host Unreachable" errors. Pings to the gateway IP apparently went to /dev/null. Traceroute attempts just timeout... eventually. It *could* be the tmobile login thing, but I doubt it -- that's supposed to redirect my first HTTP access and then use port capture (AIUI), but over eth1 my Firefox just reports "connecting to" for ~5min before finally timing out. So I've achieved associattion to the AP, received an IP... but can't get any traffic through. I know the tmobile AP is okay, because it worked with the same hardware under WXP. Sooo... any thoughts?
Shell outputs:
Omnicomm:/home/David # ifstatus eth1 eth1 device: "Cisco Systems", "350 Series Wireless LAN Adapter" eth1 configuration: wlan-bus-pcmcia dhcpcd running eth1 is up
4: eth1: mtu 1500 qdisc pfifo_fast qlen 1000 link/ether 00:0f:f8:4f:6a:23 brd ff:ff:ff:ff:ff:ff inet 10.221.165.241/27 brd 10.221.165.255 scope global eth1 inet6 fe80::20f:f8ff:fe4f:6a23/64 scope link valid_lft forever preferred_lft forever eth1 IP address: 10.221.165.241/27 (DHCP)
current lease for eth1: IPADDR=10.221.165.241 NETMASK=255.255.255.224 GATEWAY=10.221.165.225 DOMAIN='cust.hotspot.t-mobile.com' DNS=66.94.9.120,66.94.25.120 DHCPSIADDR=0.0.0.0 DHCPCHADDR=00:0F:F8:4F:6A:23
eth1 IEEE 802.11-DS ESSID:"tmobile" Nickname:"Omnicomm" Mode:Managed Frequency:2.442GHz Access Point: 00:0E:83:B6:72:4E Bit Rate:11Mb/s Tx-Power=20 dBm Sensitivity=0/65535 Retry limit:16 RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality:15/10 Signal level:-60 dBm Noise level:-100 dBm Rx invalid nwid:174 Rx invalid crypt:434 Rx invalid frag:0 Tx excessive retries:30 Invalid misc:10238 Missed beacon:0
Omnicomm:/home/David # cat /etc/resolv.conf ### BEGIN INFO # # Modified_by: dhcpcd # Backup: /etc/resolv.conf.saved.by.dhcpcd # Process: dhcpcd # Process_id: 2936 # Script: /sbin/modify_resolvconf # Saveto: # Info: This is a temporary resolv.conf created by service dhcpcd. # The previous file has been saved and will be restored later. # # If you don't like your resolv.conf to be changed, you # can set MODIFY_{RESOLV,NAMED}_CONF_DYNAMICALLY=no. This # variables are placed in /etc/sysconfig/network/config. # # You can also configure service dhcpcd not to modify it. # # If you don't like dhcpcd to change your nameserver # settings # then either set DHCLIENT_MODIFY_RESOLV_CONF=no # in /etc/sysconfig/network/dhcp, or # set MODIFY_RESOLV_CONF_DYNAMICALLY=no in # /etc/sysconfig/network/config or (manually) use dhcpcd # with -R. If you only want to keep your searchlist, set # DHCLIENT_KEEP_SEARCHLIST=yes in /etc/sysconfig/network/dhcp or # (manually) use the -K option. # ### END INFO search cust.hotspot.t-mobile.com nameserver 66.94.9.120 nameserver 66.94.25.120
Omnicomm:/home/David # traceroute cnn.com cnn.com: Temporary failure in name resolution
It took quite a while for that last error message to come up -- over
2min.
man route man traceroute
What exactly does '/sbin/route -n' show? The 'Destination Host Unreachable" message means that the network stack can't determine the hardware address of the remote host. It thinks it knows where to send the packet, but it can't find anyone to talk to. That often means your routing is fscked.
You know, this has been part of the Linux FAQ for over NINE years. The old FAQ is posted to comp.os.linux.misc weekly. The newer FAQ version is available from the LDP - try
then, it would take you longer to type 'delay in name resolution' into groups.google.com then it would for them to supply you with several thousand hits - including every newbie in town giving the correct answer.
Because you didn't include the -n option to traceroute, and used a name rather than an IP address, the application is trying to resolve the name to an IP address, and waiting till the resolver times out. Also, because you have IPv6 enabled, there will be an additional delay in name resolution while the kernel gamely tries to get an AAAA response. You might try using '/usr/sbin/tcpdump -n -i eth1' to see if there is any traffic on the interface. Who knows, you might be surprised.
Old guy
