True enough, we use nitrogen at our microwave sites that have waveguide, along with dehumidifiers.
"Dana" hath wroth:
From the Andrew Corp data sheets on waveguide and coax cables:
At one community repeater system I maintained in the early 1970's, I used a compressed air drying filter and a bicycle pump. I ran the pressure up to about 7 psi. It would leak down to about 2 psi in 3 months. I missed re-pressurizing the coax one winter and got to spend a back breaking day purging the coax. I built a small pressurization system from an air brush pump and eliminated the bicycle pump ordeal. Refridgerated dessicating system are nice, but you can get away with much less if you don't mind purging the coax every few years.
