My homebrew dongle reflector antenna extends laptop range, but...
Oct 19, 2004 Last reply: 22 years ago 6 Replies
Jump to replies (6)
After seeing the freeantennas for wireless Internet to extend the router's range, I tried a quick and dirty homebrew reflector using an auto oil funnel (soft cardboaard) and affixing half of its side with foil aluminum. Well, my marginal signal (was almost non-existent at night, for some reason) is now "Very Good" according to the [usually overly optimistic] X-Micro's 11b software.
However, I noticed that the angle and placement of the reflector and the USB dongle (hope that's the right term for the transmitter on the laptop) is very critical. Off by one inch, and there is no signal.
If there is a contest for making the most practical, cheapest dongle antenna, this is my entry. The advantage of a soft cup is its flexibility, portability. I am going to cancel my thoughts of buying a ready-made antenna.
OK. for your contest for "making the most practical, cheapest dongle antenna" this is my entry, my tin cantenna:
Alston's cantenna requires a USB extension cable while Smogkiller's simply covers the dongle on the laptop. The cantenna may get more range because it can be positioned better.
A picture of Bob's is at:
presume that Bob's looks like mine. An internal view of mine:
the folks that got me interested in USB dongle reflectors:
A USB cable comes with the dongle, so there's no added cost there.
USB adaptor on a length of a cable is always preferable to a dongle, often placing it high works well, and yes, half an inch can make a difference. Regards, Martin
Yes, but a USB dongle on a length of USB cable may work just as well and be quite a bit cheaper.
