Help Me With My Antenna Parabola, Please!
Nov 20, 2007 4 Replies
Most relevant reply
curly Bill
assuming they are as high as the antenna element? When doing the printout, just make the square remains square.
[Resend: Apparently server has connectivity problems]
OK, I'm in need of a bit more boost from my vertical omni antenna, which is just not cutting it most of the time; I need more directional grunt.
I saw this site:
and thought I'd try it, but there are two different types of reflectors and I am not sure which is the correct one for the cheapie antenna I'm using:
The element is about 7-3/8 inches long, with two corkscrew sections.
If you scroll down on the site, you'll see that there's a second page for an improvised reflector for "WET-11 5/8 Wave" antenna types. Which is the more appropriate for my antenna?
Do these reflectors "scale," that is, do bigger ones of the same proportions work the same?
Thanks for any help!
What information does your site survey yield?
Specifically, is the height of these vertical reflectors critical, assuming they are as high as the antenna element?
Remember, this is for an element about 7-3/8" high, not the small screw-on masts that come with cheap routers, for which these designs are originally intended.
