Authentication Gateway Software for Wireless?
Apr 11, 2006 4 Replies
Derek Broughton
So what's wrong with DHCP? What's wrong with openwrt? It would be easier to answer if we knew what your restrictions were.
I am looking for easy manageable authentication gateway software to manage wireless hotspots and a public LAN. The software should:
- run on Linux and/or Mac OS X.
- not rely on openwrt firmware.
- have web authentication for the users.
- have a web interface for administration and ideally accounting.
- support authentication via MySQL or RADIUS.
- not rely on DHCP.
- preferably be opensource.
I really like Chillispot, but it unfortunately has to act as DHCP server in order to work.
thanks Mark
Nothing is wrong with DHCP - the problem is that we are using a lot of features within DHCP, that Chillispot does not provide like: Hostgroups with different options, IP-reservation by MAC, dynamic DNS updating. The main problem with openwrt is that you are restricted to specific hardware - and here is already a huge variety of Wireless hardware in place.
That's why I thought it important we knew why you specified those restrictions. You're not really looking for a solution that doesn't "rely on openwrt", you want a solution that puts the authentication gateway on another computer in your network. That's probably easier than one that _must_ be on openwrt. openwrt is just another Linux OS, so if you've found something that _does_ work on openwrt, you should be able to put it on its own linux box.
How about ZoneCD? I haven't used it, but the reviews I've seen are good. I have no idea whether it will co-exist well with your DHCP, though.
I would think that you could make Chillispot use all those DHCP features - but it might be more work than you want to do.
thank you very much for your advice. I am giving ZoneCD a try. It looks interesting: Live CD, based on Knoppix/Morphix using NoCat as the gateway software. The only drawback is that the system uses an external server on the internet for the authentication stuff. But as they are using a perl based NoCat I think I may be lucky here with using perls Auth::Radius module.
