1.3 Miles PtP Link - Seeking suggestions.
Dec 13, 2006 21 Replies
SM wrote: : I've got a 1.3mi distance I'd like to do a PtP link with 2 WRT54GL's. : Its not exactly a pure LOS between the 2 locations, but the obstacles : are minimal.
After reading all of the responses, does anyone have a _non_ WRT54GL solution? I have about 0.8Miles to cover, but I would like to look at a _non_ 2.4Ghz solution, preferably something that is already weather proof.
What should I be looking for?
(Yeah, a moto canopy system looks great, but $2K + is a bit steep ).
Thanks!
=Marcel
if you need just a PtP for .8 mi why not take a look at the highgainantenna PtP 5.x radios. You can use them in the 5.8 ghz range for o/s use . They have a 40db eirp with a 23db built-in flat panel antenna. This would make the radio about 17-20 db.
this should give you 100 link quality with 30-50mb bandwidith for about 400.00.
You could also do this with the tranzeo 5.8ghz flat panel radios also
Bob smith Robert Smith Consulting
