Historical Significant Internet Communications Technology:PSTN quality NextGen TCP/IP
Feb 06, 2005 0 Replies
Historical Significant Internet Communications Technology:PSTN quality NextGen TCP/IP open original image
Seattle News, Washington (WA), WA - Feb 3, 2005
Historical Significant Internet Communications Technology BreakThrough : Immediate PSTN tranmsmission quality Next Generations TCP, not needing cumbersome QoS/ MPLS etc
Visit
to freely download for research purposes.
Microsoft, Cisco, IETF included will be very surprised 'good old ' Internet's underlying TCP/IP protocol itself can now more successfully do for PSTN quality VoIP / Multimedia instead of current QoS/MPLS cumbersome attempts.
Dr Bob Kahn had somehow perhaps foreseen something like this in his recent interview: ' ...something far bigger than existing Internet may jiust as easily again emerge ...just like Internet itself originally...from totally unexpected quarters...
-- Here is our NextGenTCP for all Windows platforms,
9x/ME/NT/Win2000/WinXP/Win2003, ready for immediate production network uses even for this 1st version. Visit
to download free.
you can easily set this up for production use on your home/ office LAN PCs. Its guaranteed SAFE not affecting systems in anyway whastsoever. Install this in your LAN/ WAN/ Proprietary Internet & immediately working corporate wide/ worldwide within minutes with immediate end2end PSTN transmissions quality among all nodes locations, not needing multimillion pounds & 6 months timeframe QOS/ MPLS etc for PSTN quality VoIP/ VideoConference
this software can be freely distributed widely with 3 months free license automatic grant , expires 1 May 2005.
NextGenTCP is like most softwares AOL...etc after someone install 1st time, even an arts educated office girl watching can repeat the steps install & use it on her own
Right attached the concise instructions for this 1st version
here is the only instructions most people ever needs, to convert their LAN/ WAN corporate networks into PSTN quality within minutes:
Download attached files in C directory, then click on winpkflt_lite to install. To run NextGenTCP bring up DOS Command Prompt & type :
C:\ NextGenTCP.exe timeout pause-interval
( Timeout values in ms eg 25 , 50 etc , set this value to the WAN/ LAN most distant locations' uncongested one way latency ie slightly more than half the uncongested ping's round trip's RTT ).
Typical values of NextGenTCP.exe 15 50 works well on most systems.
Run NextGenTCP from command prompt DOS box in each & every PCs within your LAN &/or WAN for immediate PSTN quality UDP traffics VoIP/ VideoConference/ Movie Streams within your corporate network within minutes, not needing multi-million pounds & 6 months timeline QOS/ MPLS planning.
Movie streaning/ audio file streaming tested working first time on LAN PCs (you may want to attach 2 plug & play IP phones to test).
Note: make sure your PCs' Ethernet settings are 10mbs half duplex, NOT full duplex (which turns off CSMA/ CD & introduces excessive collision latencies like 150ms. Anyway full duplex setting is usually allowed only where there are only a single PC connected to a single device)
__________________ Future Internet Today !
