Steve St>> Phonetray free works for me in these situations. A nice addition to
>> my 'always on' home file server. All you need is an old voice modem
>> that does callerid decode.
>>formatting link
>> [TELECOM Digest Editor's Note: Exactly how does Phonetray work? Can
>> you explain your experience with it in more detail for us? PAT]
> There are tons of similar programs such as Identafone. Just Google for
> 'caller id software'.
> -mhd
> [TELECOM Digest Editor's Note: Maybe you, or someone can explain to me
> how to use Google search on multiple word expressions. For example, if
> I Google for 'Patrick Townson' I get a jillion entries, but not all of
> them for that entire name: I get many entries for 'Patrick' this and
> 'Patrick' that; ditto for various Townson(s), only occassionally in
> the desired context of 'Patrick Townson'. Either single or double
> quoting the entire expression does not seem to help and with clusters
> of numbers it seems to act like a calculator. What are the rules on
> Google Searches and where can I find them? Anyone? PAT]
Put it in double quotes: "Patrick Townson". Otherwise, Google will assume you mean Patrick AND Townson.
Michael D. Sullivan Bethesda, MD (USA) (Replace "example.invalid" with "com" in my address.)
