Actually, this is good for Sprint PCS which has been in the pits. The
> benefit to Nextel is illusive. It's more than likely Sprint PCS had
> more designs on spectrum than any real benefit to Nextel.
Perhaps, but both companies will end up combining spectrum - there are towers where Nextel has antennas but Sprint doesn't, &c.
Nextel probably figured Sprint was a good partner since (as I understand it) they're dumping iDen for a CDMA-based platform, long-term.
when have mergers ever really benefitted the end user? Look at what
> happened with AT&T Wireless and Cingular. If you were an AT&T
> Wireless subscriber and you got absorbed by Cingular you basically got
> reamed and were not even given any Vaseline to make it easier on you.
What do you expect? SBC has done the same thing to hundreds of thousands of landline customers by buying RBOC's... I'd *never* use Cingular.
Steve Sobol, Professional Geek 888-480-4638 PGP: 0xE3AE35ED Company website:
