Re: Amber Alerts
Apr 14, 2006 0 Replies
I do not have any information on the subject, but I wonder in what way
> Amber Alerts are disseminated so quickly.
> [TELECOM Digest Editor's Note:
>> The AMBER Alert Plan, named for 9-year-old Amber Hagerman, is a
>> voluntary partnership between law-enforcement agencies, broadcasters,
>> and transportation agencies to activate an urgent bulletin in the most
>> serious child-abduction cases.
In NC, at least, it isn't voluntary. Most EAS messages get printed out and can be delayed, read by local staff, or ignored. Amber Alerts, like national alerts (full scale nuclear war), cut through immediately.
> Broadcasters use the Emergency Alert System (EAS) to air a
>> description of the abducted child and suspected abductor. This is
>> the same concept used during severe weather emergencies. The goal
>> of an AMBER Alert is to instantly galvanize the entire community to
>> assist in the search for and safe recovery of the child.
> The FAQ from the same fact sheet says:
>> How do AMBER Alerts work?
>> The information is then faxed to radio stations designated as
>> primary stations under the EAS. The primary stations send the same
>> information to area radio and television stations and cable systems
>> via the EAS, and participating stations immediately broadcast the
>> information to millions of listeners. Radio stations interrupt
>> programming to announce the Alert, and television stations and cable
>> systems run a "crawl" on the screen along with a picture of the >> child.
At least for radio stations, there is a chain. Secondary stations, and so on, have monitor receivers which trigger special EAS decoders to receive and print out the data, as well as record or immediately play the audio. I think lower tier stations monitor at least two stations above them, and the EAS equipment is hooked into the audio chain where it can over ride everything else.
