AT&T-iPad security breach may be worse than first thought [telecom]
Jun 16, 2010 0 Replies
AT&T-iPad security breach may be worse than first thought [telecom] open original image
By Peter Bright Ars Technica
Researchers looking into the security of GSM phone networks are suggesting that the recent breach, which saw tens of thousands of e-mail addresses and ICC-IDs inadvertently disclosed by AT&T, could have far more significant implications than a bit of extra spam: attackers can use the information to learn the names and phone numbers of the leaked users, and can even track their position.
The problem is that ICC-IDs-unique serial numbers that identify each SIM card-can often be converted into IMSIs. While the ICC-ID is nonsecret-it's often found printed on the boxes of cellphone/SIM bundles-the IMSI is somewhat secret. In theory, knowing an ICC-ID shouldn't be enough to determine an IMSI. The phone companies do need to know which IMSI corresponds to which ICC-ID, but this should be done by looking up the values in a big database.
In practice, however, many phone companies simply calculate the IMSI from the ICC-ID. This calculation is often very simple indeed, being little more complex than "combine this hard-coded value with the last nine digits of the ICC-ID." So while the leakage of AT&T's customers' ICC-IDs should be harmless, in practice, it could reveal a secret ID.
