Anyone knows how to connect to a router?
Oct 29, 2005 5 Replies
Tim
This is true.. Ok, I start with this... I will deny everything and forget about logging for now. (Now, nothing can come in or go out unless I allow it) block in log quick on eth0 from 192.168.1.1 to any block in log quick on eth0 from 192.168.1.0/24 to any (This should allow…
Hi!
I have to connect to a router to share the bandwith cause my sister moved in, anyone know how to do this?
I'm using FreeBSD and IPFW for the firewall.
Here are the rules I wrote.
"$IPFW" add 1 set 1 check-state ip from any to any "$IPFW" add 10 set 1 drop log all from me to any in recv eth0 "$IPFW" add 20 set 1 drop log all from 192.168.1.0/24 to any in recv eth0 "$IPFW" add 30 set 1 permit all from any to any via lo keep-state "$IPFW" add 50 set 1 permit log tcp from me to 192.168.1.0/24 53 out setup keep-state "$IPFW" add 60 set 1 permit log udp from me to 192.168.1.0/24 53 out keep-state "$IPFW" add 70 set 1 drop log all from any to me in "$IPFW" add 80 set 1 permit all from 192.168.1.0/24 to any keep-state "$IPFW" add 90 set 1 drop log all from any to any "$IPFW" add 100 set 1 drop all from any to any
For some reason I can't connect to the damn router.
I also tried with IPF
Here are the rules I came up with..
--------------- block in log body quick on eth0 from 192.168.1.1 to any block in log body quick on eth0 from 192.168.1.0/24 to any pass in quick on lo proto icmp from any to any keep state pass in quick on lo proto tcp from any to any keep state pass in quick on lo proto udp from any to any keep state pass in quick on lo from any to any pass out quick on lo proto icmp from any to any keep state pass out quick on lo proto tcp from any to any keep state pass out quick on lo proto udp from any to any keep state pass out quick on lo from any to any pass out log or-block body quick proto tcp from 192.168.1.1 to
192.168.1.0/24 port = 53 keep state pass out log or-block body quick proto udp from 192.168.1.1 to
192.168.1.0/24 port = 53 keep state block in log body quick from any to 192.168.1.1 pass in quick proto icmp from 192.168.1.0/24 to any keep state pass in quick proto tcp from 192.168.1.0/24 to any keep state pass in quick proto udp from 192.168.1.0/24 to any keep state pass in quick from 192.168.1.0/24 to any pass out quick proto icmp from 192.168.1.0/24 to any keep state pass out quick proto tcp from 192.168.1.0/24 to any keep state pass out quick proto udp from 192.168.1.0/24 to any keep state pass out quick from 192.168.1.0/24 to any block in log body quick from any to any block out log body quick from any to any block in quick from any to any block out quick from any to any
Anyone knows how to fix this? I've been at this for over an hour! Thanks......
This is true..
(This should allow incoming connections) pass in quick on lo eth0 icmp from any to any keep state pass in quick on lo eth0 tcp from any to any flags S keep state pass in quick on lo eth0 udp from any to any keep state pass in quick on lo from any to any
(Next rule should allow outgoing connections) pass out quick on lo eth0 icmp from any to any keep state pass out quick on lo eth0 tcp from any to any flags S keep state pass out quick on lo eth0 udp from any to any keep state pass out quick on lo from any to any
The last pass should be, I think. pass out quick eth0 icmp from any to any keep state pass out quick eth0 tcp from any to any flags S keep state
That should work... But it doesn't. Could the router be blocking my connections?
I will need two interfaces. I want to JAIL sendmail and allocate a separate IP..
Thanks for any help you offer.
This is what I wanted to do, but she won't.
That is the problem I'm having.. The router has a 4-port switch, I can connect to the net with no problems when I disable the firewall on my computer. I would like to run a firewall behind the router, I have no idea how secure they are.
If I could get my computer to connect to it.
I can talk to the router with out a firewall. How secure are Linksys routers? It only cost like $50.
I will guess that router IP is 192.168.1.1.
Not familiar with IPFW, although it does look as if you might be blocking traffic from the router.
Those would seem to drop all traffic from the router, although it would allow external packets that are being routed.
I'm not clear on what those are supposed to do. On my reading, you already blocked those packets with the "quick" option, so they won't reach down this far in your rules. Or do you have two interfaces, so that the early rules only block on the wrong interface and the rules immediately above accept on the correct interface.
Either way, you haven't given enough info for people to be able to help.
Thwo possibilities.
1) Buy asnother ethernet card for your computer. Run a line from her computer to yours. Haveyour computer act as a masquarading forwarder for hers. This requires your macine to be on whenever hers is.
2) install an intelligent router which will make the connections with the ISP. You and she just plug into the ethernet ports on the router.
The router will handle all the negotiations with the ISP.
First you turn off all firewalling. You find out what address the router uses, and connect to it with http. You set it up. Then when you know you can talk with it, and everything works, then set up a firewall on your own machine.
If the FreeBSD box is the router, have a look on this:
If not, please understand, that my crystal ball device is in the washer, so I cannot find out your complete network configuration here.
The ipfw configuration does not tell me your topology and addressing. But those two lines are suspicous:
| "$IPFW" add 10 set 1 drop log all from me to any in recv eth0 | "$IPFW" add 20 set 1 drop log all from 192.168.1.0/24 to any in recv eth0
You could read this one, though:
Yours, VB.
