Autonegotiation @ 100 / 1000BASE-T - why in another sublayer of PHY
Mar 15, 2007 3 Replies
Jump to replies (3)
Hello,
little question, that does not find it's answer in google (no matter of what angle I strike it) - in 100BASE-TX, autonegotiation function is placed just before the RJ-45 (MDI), under the PMD (physical medium dependent - at the bottom of PHY), and then - in 1000BASE-T it is defined as a functional block of PCS (physical coding sublayer - at the top of PHY).
Simple q: W H Y ? ? ?
Does anyone has an answer? Or does anybody has skills to dig this simple info from the web?
thanks in advance, banan
I'm not sure it is an/the answer, but autoneg in 100BT was (at least initially) optional. I don't think it was ever optional in 1000BT. Perhaps that has something to do with where it is placed? I suspect the folks over in comp.dcom.lans.ethernet would know.
rick jones
Thanks, will go there and check out.
bio
I don't believe that it existed at the beginning of 100baseTX.
I used to have a 3C250 (bought cheap on eBay), one of the original
100baseTX repeaters. No 10baseT mode, but it does make a good door stop.
-- glen
