wrong cable interface GigabitEthernet0/1
Nov 09, 2006 2 Replies
Hey all, I'm having an issue while trying to connect my switch to my router. I tried Googling the life out of the error but came up short.
Nov 9 17:13:05.953: IP ARP req filtered src xxx.xxx.xxx.198
0005.e700.3049, dst xxx.xxx.xxx.197 0000.0000. +0000 wrong cable, interface GigabitEthernet0/1
I can connect a crossover via my laptop and connect w/o issues but the moment I connect the switch I get those errors. I also cannot connect to any vlan interfaces either. Any thoughts (TIA)
"wrong cable"
Maybe that's a clue? What cable are you using?
"I can connect a crossover via my laptop and connect w/o issues "
Connect to what with your laptop. The router or the switch?
This message means the router has seen an arp request for an address that doesn't belong to the interface it arrived on, i.e. if the router interface had an ip address of xxx.xxx.xxx.1/25, then as far as it's concerned neither xxx.xxx.xxx.197 or xxx.xxx.xxx.198 are valid addresses on that interface and seeing arp requests for those addresses on that interface can only be a mistake.
Some address is configured wrong or something is plugged in where it shouldn't be.
