Using BRI interface as backup
Nov 10, 2005 5 Replies
Jump to replies (5)
Hello,
I have an production router (Cisco 1721) running over ADSL. I also have a PIX 515e sitting behind it. The public IP of the PIX is where we have several public services (MX Record, HTPPS Extranet). So I am really tied to that IP address.
The ADSL line very occassionaly fails for a few hours (once a year maybe) and so I would like to take advntage of the BRI interface on my
1721 as a backup when the ADSL goes down.
My question is:
How can I setup the router to use the ISDN line as a backup and NOT lose all my public services tied to that public IP address?
The config does not have to be automatic. If manual changes need to be done to the config that is acceptable.
Thank you,
Pedro Sosa
Will your ISP route your range of public IPs attached to the PIX over the ISDN? It is possible ive done it for many customers but involves a RADIUS change at their end and thats if they permit it.
Cheers
Matt
The ISP (Telefonica) here in Spain is awful. I could not even get them to agree to use a Cisco router. They gave us one of thier routers (Juan=B4s Router or something like that). So I put in the 1721 on my own, and for the price I pay every month I don=B4t expect ANY support. I would need to talk to about 50 people before anyone even understood what I am trying to do, and then they would say:
You cant do that!
Sorry but on this one I am alone.
You cant do that!
Oh dear. :( Well because when you fire up your ISDN on a different IP address you wont be able to route your external PIX IP addresses even for internet access unless they are a little bit flexible.
If they can add
ip:route=
on your ISDN login at their RADIUS you will be a huge leap further. Or can you use your ADSL login as the ISDN login?
Cheers
Matt
Matt,
Thanks for you advice. So what you are telling me then is without thier (Telefonica) help I have no way of doing this on my own?
Cheers,
Pedro
Yes in a way. You could manually reconfigure the IP on the PIX perhaps but it will require you reconfiguring things when the ADSL goes down. Bit of a nightmare way though.
Cheers
Matt
