Idle TCP session over Cisco PIX
May 17, 2005 1 Replies
Hello A TCP session with no keep-alive (in accordance to rfc1122), is closed by Cisco PIX firewall (routing mode, NAT). Increasing "timeout conn" seems problematic. How Cisco PIX should be cofigured to enable a spesific idle session? Ilan
In article , Ilan wrote: :A TCP session with no keep-alive (in accordance to rfc1122), :is closed by Cisco PIX firewall (routing mode, NAT). :Increasing "timeout conn" seems problematic. :How Cisco PIX should be cofigured to enable a spesific idle session?
cross-post, don't multi-post.
See my answers in comp.protocols.tcp-ip or comp.security.firewalls... both saying "You can't do that... unless maybe you are using 7.0(1)".
