Cisco 887 & 2621XM policy maps
Apr 03, 2012 1 Replies
I,m trying to use a config from a Cisco 887 router - C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M7 - on a 2621XM - C2600- ADVENTERPRISEK9-M Version 12.3(14)T7. However, I see some config lines used on the 876 cannot be used on the 2621 e.g.
887: ! class-map type inspect match-all sdm-cls-VPNOutsideToInside match access-group 120 !
2621: cannot use "class-map type inspect ..." instead I have to use ! class-map match-all sdm-cls-VPNOutsideToInside match access-group 120 ! Also some policy map commands are not available on the 2621:
887 match protocol https - (can only use match protocol http on 2621) ! Is there any where I can see how to use the 887 config on the 2621. Thanks
Firstly, if you are using the 2621XM in a production network be aware that Cisco ended support for these on 25th March this year.
887 will probably have a later IOS version (15.0 or 15.1) compared to 2621XM which will have at the latest 12.4T. You need to establish which versions you have by using the "show version" command then you can research them using Cisco Feature Navigator.
