Cisco 827 ADSL Configuration Help
Aug 29, 2007 5 Replies
Jump to replies (5)
I don't have AOl so I can't say anything about that, but I would get rid of the access-lists and firewall and concentrate on the basic connectivity first.
under ATM0 add: dsl enable-training-log (so that you can see the training with show dsl int atm0)
Use the 827 ADSL troubleshooting guide if you encounter difficulties
Looks OK. Never seen anyone use pvc 0/100 before. Maybe AOL do?
In the US I think is is often 0/35. The other thing is that pap is not always supported chap is more common I think. Easy to try one then the other though or even configure both, I think it tries both,
run a debug ppp
your isp may have another route that you will use for default
the debug ppp will show you the ip with whom you are negotiating
