Cisco 501
Nov 23, 2005 2 Replies
I have a static IP address from my ISP. I also have a router with a built in Modem so I plug the router into the telephone line. If I make a direct connection from my router to my PC with the following addresses on my PC everything works fine, I get a connection to the internet (can view webpages):
IP: 194.97.248.40 Subnet: 255.255.255.250 Default Gateway: 194.97.248.39
Preferred DNS : 193.167.64.5 Alternate DNS : 194.97.230.30
As soon as I connect my Cisco 501 PIX in between the PC and the router, I don't get any internet connection. Here are the steps I am following to configure the firewall, so please guide me where I am going wrong:
I start the PDM by going to https://192.168.1.1/startup.html
Once started and authenticated get the Basic Configuration and I leave the default values ( PIX Host Name = pixfirewall, Domain Name: ciscopix.com)
On the next page "Outside Interface Configuration" I leave the "Speed to Auto" and I select "static IP address" and input the following details IP 194.97.248.40, Subnet Mask: 255.255.255.250 and Default Gateway: 194.97.248.39
On the next page I leave the remote VPN page empty
On the next page I also leave the Auto update Configuration empty
On the next page "Other Interfaces Configuration I can see the Inside and outside interface settings and the inside has a security level of
100 and the outside has 0.
On the next page "NAT and PAT Configuration" I select "do not translate any addresses.
On the next page I disable the DHCP because I can allocate a specific IP for the PC connecting to the Firewall.
After applying all these setting and saving them. I specify TCP/IP for my PC with the following addresses:
IP: 192.168.1.10 Subnet Mask: 255.255.255.0 Default Gateway : 192.168.1.1
I try to connect to the internet but I will not let me connect. For some reason Skype is able to connect which is quite strange.
Do I need to configure anything more? Why does it not allow me to connect to the internet?
When I remove the firewall I am getting a connection. Please can you guide me?
Thank you, James
Hi
if u ask me activate NAT and it will work.
Here's your problem: you are using your static IP address on the outside interface and an RFC 1918 address on the inside interface, yet you have NAT/PAT turned off. What do you expect is translating your external address (184.97.248.40) to your internal address (192.168.1.10) if you have NAT/PAT turned off?
