ASA5510 unable to talk between ethernet 0/1 and 0/2
Jan 21, 2010 1 Replies
All,
I have setup ASA5510 and 0/1 and 0/2 were unable talking to each other. Here is the configuration: ethernet 0/0 outside security level 0 ethernet 0/1 inside security level 100 ethernet 0/2 private security level 100
same-security-traffic permit inter-interface access-list nonat extended permit ip 192.168.2.0 255.255.255.0
192.168.2.0 255.255.255.0 access-list nonat extended permit ip 192.168.3.0 255.255.255.0
192.168.3.0 255.255.255.0 nat (Inside) 0 access-list nonat nat (Inside) 1 0.0.0.0 0.0.0.0 nat (private) 0 access-list nonat nat (private) 1 0.0.0.0 0.0.0.0
The servers on both side were able to access internet.. When I try to ping and the following error log from the firewall log: portmap translation creation failed for icmp src Inside:
192.168.2.151dst private:192.168.3.101(type 8, code 0)
Any help is appreciated.
The ASA has no state about such a connection. So you are required to guide the initial way though the system: static (inside,private) 192.168.3.0 192.168.3.0 netmask 255.255.255.0 static (private,inside) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
Have fun.
