Access List Allow Traffic From a Public IP and port
Dec 06, 2005 1 Replies
Hi all on a 1720 with ios 12.2(8)T10 i have some access list and with these i deny the traffic from all the tcp ports except from the well known (80, 23, etc). Now I have to allow the traffic from some specific public ip on some specific ports to a specific host of my network.
First question: Is right the access list that you find down in this document?
Second question: I have to allow the same for these ip 80.207.109.105 -
80.207.109.110 - 80.207.109.119 - 80.207.109.121 - 80.207.109.122 -
80.207.109.123 - 80.207.109.124, is there a method for don't rewrite the lines that the traffic for one of the public ip? (i'm thinkng at the subnet but i do not know how)
Excuse me for my english and many thanks to all Gian Paolo
access-list 102 permit tcp any any eq www access-list 102 permit tcp any any eq telnet access-list 102 permit tcp any any eq ftp access-list 102 permit tcp any any eq pop3 access-list 102 permit tcp any any eq smtp access-list 102 permit tcp any any eq 443 access-list 102 permit udp any any eq 443 access-list 102 permit udp any any eq 23 access-list 102 permit udp any any eq 21 access-list 102 permit udp any any eq domain access-list 102 permit udp any any eq 110 access-list 102 permit udp any any eq 25 access-list 102 permit tcp any any eq domain access-list 102 permit tcp host 10.10.10.101 host 80.207.109.110 eq 80 access-list 102 permit tcp host 10.10.10.101 host 80.207.109.110 eq 389 access-list 102 permit tcp host 10.10.10.101 host 80.207.109.110 eq 443 access-list 102 permit tcp host 10.10.10.101 host 80.207.109.110 eq 2560 access-list 102 permit tcp host 10.10.10.101 host 80.207.109.110 range 7001
7002 access-list 102 permit tcp host 10.10.10.101 host 80.207.109.110 range 8080
8084 access-list 102 permit tcp host 10.10.10.101 host 80.207.109.110 range 8090
8091 access-list 102 deny ip any any
Just need to understand you acl in order to say if it's right or not....
Is this an Internet facing router? If so.... Is there a reason you're allowing ports like 23 and such from the general internet? maybe a better way is to deny all and then allow only what you need specifically.... If you require a terminal type access, I would use SSH...
do you really want port 389 or did you mean 3389 (remote desktop)
For 80.207.109.x, If this is from the internet, you should have a device doing network translation for your "10.10.10.101" system...
ie...
using something like this is less burdensome but can accomplish the same thing I THINK you're trying to achieve...( you can lock this down even further... this says "if it's not one of the listed denys... allow it)
! interface ip access-group spooke in ! ip access-list extended spooke remark "EXAMPLE ACL" deny ip any 0.0.0.0 0.255.255.255 log-input deny ip any 10.0.0.0 0.255.255.255 log-input deny ip any 127.0.0.0 0.255.255.255 log-input deny ip any 169.254.0.0 0.0.255.255 log-input deny ip any 172.16.0.0 0.15.255.255 log-input deny ip any 192.0.2.0 0.0.0.255 log-input deny ip any 192.168.0.0 0.0.255.255 log-input deny ip any 224.0.0.0 7.255.255.255 log-input deny ip any 255.0.0.0 0.255.255.255 log-input deny ip any host 255.255.255.255 log-input deny 55 any any log-input deny 77 any any log-input deny pim any any log-input permit tcp host eq telnet deny tcp any any eq telnet log-input deny tcp any any eq 135 log-input deny udp any any eq 135 log-input deny tcp any any eq 137 log-input deny udp any any eq 137 log-input deny tcp any any eq 139 log-input deny udp any any eq 139 log-input deny udp any any eq snmp log-input deny udp any any eq 1993 log-input deny udp any any eq tftp log-input deny udp any any eq bootpc log-input deny udp any any eq bootps log-input permit tcp host host 80.207.109.110 eq
3389 (or 389) permit tcp host host 80.207.109.110 eq range 7001 7002 permit tcp host host 80.207.109.110 eq range 8090 8091 permit icmp any any echo-reply log-input deny icmp any any permit ip any any log-input no cdp run
