A SECUR Question
Aug 02, 2005 1 Replies
Which of the following actions can you to prevent newly configured commands from being sent to a target router? A. delete B. remove C. undo D. clear-commands E. refresh
This is a question from TestKing but without a answer.
test king.
You phuqin loser.
Test king is for losers and morons who think a cert will get them a job.
well it might but when u p*uq up someones network, router, business......
Good phuqing luck finding another job. You will be blacklisted and will find your employment
opps limited to the BK lounge and Mcee dees.
So repeat after me....."Would you like fries with that".
