I have the older WAP54G (7 LED's, 1.08 firmware). I cannot connect to the internet (from both a Dell (intel 1400) wireless adapter (running XP Pro-SP1) or a viewsonic PC card (running XP-Pro-SP2) with WEP enabled. I can connect to the access point with WEP enabled, but I get the "X" for the internet and the limited connectivity message. In both cases I had to manually supply an IP address, gateway, and DNS server address. I was told there is a 1.09 firmware upgrade somewhere as Linksys tech support states this version doesn't support the new firmware 2.0x.
- posted
18 years ago
