Hi every one..
I would like to introduce SatGuide; SatGuide is India?s 1st GPS Navigation Solution which can guide you from Kashmir to Kanyakumari across all major highways in the country. In addition, detailed intra city roads and points of interest are also available for major metros. With SatGuide, a user can navigate to any chosen location by entering the destination as the input, SatGuide resolves the current location from GPS satellites and suggests the best possible route on a map displayed on the screen. While driving, it prompts the user all along the way through voice commands with directions to reach the Destination. SatGuide is compatible with all devices which have the following features; The device should be based on windows mobile 2003/2003Se/5.0 Versions. The screen size of the device should be 240x320. It should have an inbuilt GPS receiver or GPS port to extend it to external GPS receiver. So if you have any windows mobile device phone or PDA etc with the above specs, then you just buy software from us. Please logon to 'Welcome to SatGuide ? India?s 1st GPS Navigation'
-----Siddeshwar.
