Looking for product. 110 outlet plugin device that acts as a switch based on power or no ...
Threaded View
I don't want to control the outlet.  I just want a product that is essentially a relay plugged into an outlet.  When there is power the contacts are closed.  When there is not power the contacts are open.
Re: Looking for product. 110 outlet plugin device that acts as a switch based on power or no power.
On Sat, 11 Oct 2014 13:02:13 -0700 (PDT), Joseph Shook
You could buy a relay and plug it into an outlet!
Seriously, if you explain what you are trying to do, you might get
some better suggestions.
I have an front porch motion sensor light.  I have a screw in outlet so I h
ave power access.  I then have a ghost that can be activated via a switch.
 So I want a product that can be plugged into the outlet.  When the light c
omes on the switch is closed, the ghost turns on.  I do not want to wire up
 110 to a relay.  The only wiring I want to do it to the switch that is exp
osed from the battery powered ghost.
On Sat, 11 Oct 2014 13:48:17 -0700 (PDT), Joseph Shook
You could plug a small "battery emininator" into the outlet and use it
to power the ghost instead of its batteries.
I never see typos until the message is long gone.  That would be
battery eliminator (ie, a small wall wort power supply available at
Radio Shack and similar places).
So I went down this path.  I used one of my 4.5 wall wort 4.5 supplies and
soldered in.  This does supply power without batteries but actually does no
t turn on the ghost with just presence of power.  I still need to close the
 circuit with either the built in motion sensor(poor) or push the external
mountable button.  I am back to my original desire; wish there was a standa
rd 110 wall plugin relay switch.  Technically I there is probably a more co
rrect definition (name) for that.
Now that I have cracked the case and brought out the solder, I might as wel
l solder in a solid state relay.
Anyway thanks for the suggestions.
 I have power access.  I then have a ghost that can be activated via a swit
ch.  So I want a product that can be plugged into the outlet.  When the lig
ht comes on the switch is closed, the ghost turns on.  I do not want to wir
e up 110 to a relay.  The only wiring I want to do it to the switch that is
 exposed from the battery powered ghost.
Most of those Halloween, so called, motion detectors, are really light
level detectors ... which I guess really detects motion as light levels
change. Anyway, maybe you could point the detector towards the light and
when you turn it on, it will fire. Maybe you'll have to flicker the
light on and off a few times ... hey, that will add to the ambiance,
too. For years I did Halloween and one of my 1st gadgets was to blink
the front porch light using radio audio to trigger a triac to make the
light blink, look random. This scheme also worked good to run a sting of
mini Christmas lights inside skulls or pumpkins to make it look like
candles flickering. But now those flickering electronic candles are
pretty cheap.
Thanks Art.
That makes sense, that would have been the simplest solution and so obvious
 now that you pointed it out.
and soldered in.  This does supply power without batteries but actually doe
s not turn on the ghost with just presence of power.  I still need to close
 the circuit with either the built in motion sensor(poor) or push the exter
nal mountable button.  I am back to my original desire; wish there was a st
andard 110 wall plugin relay switch.  Technically I there is probably a mor
e correct definition (name) for that.
 well solder in a solid state relay.
 so I have power access.  I then have a ghost that can be activated via a s
witch.  So I want a product that can be plugged into the outlet.  When the
light comes on the switch is closed, the ghost turns on.  I do not want to
wire up 110 to a relay.  The only wiring I want to do it to the switch that
 is exposed from the battery powered ghost.
t
Site Timeline
