Ethernet switch flooding packets?
Threaded View
Hi All,
I did a WireShark packet trace this evening on the network.  I was
surprised to see quite a few packets that weren't meant for me.
Naturally I saw packets from my PC to the network, some replies, and
broadcasts such as ARPs and Windows name registrations.  However, I
also recieved packets addressed to other host's IP addresses and MAC
addresses.  (I am, of course, the only PC connected to that particular
switch port - I'm not hanging off a hub that's connected to the switch
port).
My understanding of networking is that as soon as I send an Ethernet
packet, the switch 'knows' my MAC address is on 'my' Ethernet port.
When forwarding packets, it won't bother sending me packets that
aren't destined for my MAC address.
I think this is a symptom of networking problems; we have a *huge*
broadcast domain of thousands of Ethernet outlets spread across many
buildings, and quite a few secondary VLANs that don't have anywhere
near as many outlets, but still distributed across the many buildings.
The network is mainly made up of HP ProCurve 26xx switches.
My assessment is that we probably have more MAC addresses across all
the VLANs that the HP ProCurve fabric is capable of handling, and so
old learned addresses are being dropped as new ones are learned so the
fabric is flooding packets.  It's by no means all packets, but, say
5-10 per second.
What do you think?  Do we need to think about segmenting into separate
Ethernet domains separated by L3 switches?
Kind regards,
Anwar
Re: Ethernet switch flooding packets?
anwarmahmood38@googlemail.com wrote:
(snip)
Certainly 5 or 10 packets/second won't overload the network software.
You might check the MAC address cache size in the switches.  Even if
you have more hosts, it is likely that they won't all be in heavy
use at the same time.
It might be that the backbone links have somewhat more load, but
10 packet/sec is fairly small for networks now.
I would probably suggest more study before deciding on L3 switches.
-- glen
So it's OK (and, I guess normal and accepted) that a switch is
(probably) flooding unicast packets (that are, of course not
broadcasts)?  I thought this was a no-no?  How common is this?
Depends.
A switch will flood unicast when the destination address is not in the
learned address table of the switch.
An address enters those tables when it is seen as a source address,
and leaves the tables after some time when not seen again as a source
address of other packets.
Common problem 1, in my experience: the timeout for the switch address
table is shorter than the ARP timeouts used by some of the communicating
hosts, and such hosts do unidirectional messaging. Initially, the destination
host for such messages will show itself with an ARP reply, populating the
switch address table, and messages to it will not be flooded.  But with
unidirectional traffic, that destination host does not send anything back.
So its address will timeout in the switch address table eventually.
From then on, the unidirectional messages will be flooded. A periodic ARP
request from the source host, even unicast, will elicit further ARP replies
from the destination, again populating the address table.
I've seen two different cases of such unidirectional messaging causing
flooding. One was Cisco netflow export data. The other was in the context
of a load balancer setup with triangular dataflow, i.e. one VLAN transports
requests from Internet through loadbalancer to some server, but the replies
of the server flow back to the Internet on a different VLAN or LAN.
I think that similar things could happen with host based ethernet
adapter "teaming" with two host ports connected to different switches
in the same switch cloud.
Such problems are fixed by either making the sending hosts periodically
ARP more often (the loadbalancer, in my scenario above), or by making
the timeouts of the switch address tables larger (than a common timeout
on all the hosts. we set it to 999 seconds).
best regards
  Patrick
Hi Everyone,
Thanks again for your replies.
Glen, I acknowledge 10 frames/sec wouldn't be considered a "flood", I
was merely using the Ethernet switching terminology - if a switch
doesn't know which individual port to push a frame out to, it will
"flood" them to all ports.  I've only done a short capture at one
location at one time, so the magnitude of the problem is certainly
inconclusive.
Patrick, I don't think this is a switch address timeout.  In the
frames that I saw, I saw some packets from my PC to a server on the
other end of a router, and the corresponding replies.  Hence "my"
switch has "learnt" that my MAC address is on my port, and the
router's MAC address is on the uplink port.  If I exchanged no more
traffic for the timeout period, then my address would of course
timeout and I would be flooded.  HOWEVER, just a few packets
(milliseconds) later, the switch is forwarding unicast packets on my
port that aren't for me.  I think this is because
 - the switch as 8K MAC address table.
 - every PC on each port gets added to the table when it transmits (as
it should)
 - however, because there are many thousands of MAC addresses on the
Ethernet fabric, they are all being added as belonging to the "uplink"
port
 - these are replacing the entries in the MAC address table about
which PCs are on the "local/edge" ports
    - this is happening so fast that I'm recieving unicasts addressed
to other MAC addresses on my computer, even though I just transmitted
milliseconds ago
Hope this is making sense!
Kind regards,
Anwar
(snip)
Yes, I was just trying to indicate the scale involved.  It would
sound funny to call it a trickle in the ethernet standards.
Yes, but so are all the other ports.  Note that the switch, by design,
doesn't assume one host per port, even though, as you say, it isn't
an uplink port.  When the MAC address times out for another port,
even the uplink port, those packets are sent to you.
Are there more than 8000 on the subnet (or VLAN)?  In the
first post, it sounds closer to 1000 than 8000.
Putting your MAC in the cache doesn't stop others from being
sent to you.  Only putting the other host in the MAC cache
for a different port will do that.   As I said, one way that
happens is if the host goes down and stops replying.  Until
it is out of the ARP cache, the packets will still be sent.
When it is out of the ARP cache, ARP broadcasts will be sent,
and you will see those.
The real answer is that if you really have 8000 hosts then yes,
you should go for L3 switches or routers to subnet the network.
Many people like to keep it below 250 (for a convenient netmask)
but for reasonably traffic levels and speeds 1000 is probably fine.
Maybe 2000, but not 8000.
The reason for the change is not that a few packets leak through,
but that it really is too crowded.
-- glen
Hi Glen,
Thanks for your reply.  The number of Ethernet hosts is around 5K on
the primary VLAN, but each switch is managed (via a separate VLAN, of
course) so will have it's own MAC address.  I don't know how many
other VLANs there are are or how many hosts each has.
Interestingly, I've just done another capture (it's about 10:15am, so
a peak time on the network; yesterday I did it around 6.50pm) and I'm
seeing no "foreign" unicasts *whatsoever* - very peculiar.
Kind regards,
Anwar
Define "huge" :)  The PDF datasheet for the 2610:
http://www.hp.com/rnd/products/switches/HP_ProCurve_Switch_2610_Series/overview.htm
http://www.hp.com/rnd/pdfs/datasheets/HP_ProCurve_Switch_2610_Series.pdf
suggests an 8000 entry MAC table.
I think you should call them routers :)
rick jones
not actually in hp procurve...
portable adj, code that compiles under more than one compiler
these opinions are mine, all mine; HP might not want them anyway... :)
feel free to post, OR email to rick.jones2 in hp.com but NOT BOTH...
BTW, a web search for "procurve mac table size" seems to be reasonably
effective at getting decent hits across the procurve family.
rick jones
oxymoron n, Hummer H2 with California Save Our Coasts and Oceans plates
Hi Rick,
Thanks for your reply.  I'm aware of the 8K address table, but I'm
being a little vague because I'm not part of the networks team and
don't have all the specifics;
 - I believe we use mainly 26xx at the edge, but I'm unsure what we
use at the distribution layer
 - I know roughly how many hosts we have on the main VLAN, but not
across all the (many and varied) secondary VLANs
Rick, is it normal and acceptable for a network to be flooding unicast
packets?  (I accept it's how it's designed, but didn't realised it was
OK)
(snip)
I think 10/sec is not considered a flood.  Cache entries time out,
and packets are sent to all ports until the entry is restored.
If the destination is down, and doesn't reply, the entry will never
be added to the cache.  Broadcasts are sent to all ports, by
definition.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1234420712210+28353475&threadId=1161128
reminds you that you should check for firmware upgrades.
-- glen
On 12 Feb, 05:14, "anwarmahmoo...@googlemail.com"
Firstly:-
- a few leaked unicasts a second are of no concern to me at all.
- a network of 5000 hosts in a broadcast domain *is* of concern.
  It is not *necessarily* incorrect and may be well designed
  taking into acccount the known behaviour of the hosts and the
  network equipment however it would be rather unusual to say the
  least.
So:-
Yes it is OK to see some flooded unicast packets - in the sense that
it is
inevitable in some cases. It happens by design.
Some considerations with regard to the number of hosts in
a broadcast domain are -
Resultant 'background' broadcast level -verses-
 - capacity of weakest device to process the 'unwanted' broadcasts
 - capacity of slowest link to carry 'unnecessary' broadcasts
If you are using a network with spanning-tree controlled redundant
links then the behaviour when a link fails might be of concern. On
a topology change:
 - Forwarding database (fdb) aging time is reduced to 15 seconds for
a
   time.
- Switches may have to re-learn the whole fdb and switches have
  a learning rate that may be dependent on the CPU. During
  learning unknown unicasts are flooded. With such a large number of
  hosts it may take some time to re-establish the fdb.
Finally:
Such a design is on current terms not normally 'good' practise
however without knowing much, much *much* more about it is
not possible to say whether the design is satisfactory or not. The
best measure of all of course is *does it work*.
My guess would be that if it does work every day then it has
been well designed. If such a network had been thrown together
there seems a decent chance to me that it might break from
time to time.
Site Timeline
