All,
I have a PIX 5i5E configured that permits outbound connections from inside our network. However I can't get it to permit inbound ones. I know this should be fairly simple, I think the complication is we aren't doing NAT, and are using the same addresses inside as outside. Here's the revelant part of our configuration.
PIX Version 7.0(4)2
! we use NAT control but use our real addresses on the inside nat-control global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0
interface Ethernet0 nameif outside security-level 0 ip address A.B.50.14 255.255.255.0
interface Ethernet1 nameif inside security-level 100 ip address A.B.70.1 255.255.255.0
route outside 0.0.0.0 0.0.0.0 A.B.50.1 1
! So far this part works as it should, here's ! the part I'm having trouble with. Lets say I ! I have a web server at A.B.70.50, From what I've ! read, I would have thought the following would ! permit inbound traffic to it.
access-list permit_web extended permit tcp any host A.B.70.50 eq 80 access-group permit_web in interface outside
static (inside,outside) A.B.70.50 A.B.70.50 netmask 255.255.255.255
But, this fails. My thinking was to allow a connection for the address of the web server. So when this failed, I thought, maybe I allow the connection on the outside interface, like:
static (inside,outside) A.B.50.14 A.B.50.14 netmask 255.255.255.255
Even though, if this worked, it would allow inbound connections to every system behind A.B.50.14 on the PIX. But even this doesn't work.
I've looked pretty carefully through _Cisco PIX Firewalls_ (Behrens, et al) and through other postings in this group, but they all use NAT / PAT. In fact, it seems as though the static(,) command pretty much expects some form of address translation, and isn't very happy unless it occurs.
Thanks in advance for any help.
B Squared ========================================================================= I've gone to hundreds of fortune-tellers' parlors, and have been told thousands of things, but nobody ever told me I was a policewoman getting ready to arrest her. --Unknown NYC Detective
