Failry simple VPN Lab
Threaded View
Hello all,
I am trying to learn a little more about IPSec VPN's using Cisco
equipment.  I am using a 2651 and a 1751, both with a VPN accelerator
card.  The 2600 is using c2600-ik9o3s-mz.122-15.T2 and the 1700 is
using c1700-k9o3sy7-mz.122-15.T17.  Using the Cisco SDM configurator
tool I setup a site-to-site VPN using a pre-share key on the central
end as well as a easy VPN server so clients could connect.  On the
remote end I setup the same site-to-site connection.  After all of this
the clients are able to connect and ping various addressed without a
problem, but the site-to-site connection is still having problems. I
have been through it several times, both in CLI and SDM and cannot see
what is probably obviously wrong.  What am I missing?  The configs are
as follows.
(I have the two routers connected together in my lab with a cisco 3550
switch and separated by VLANS.  VLAN 1 is my central internal VLAN,
VLAN 2 is the 'Internet' VLAN, and VLAN 3 is the remote Internal VLAN)
-----------------------------------------------------Start Central
Config
!version 12.2
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Central_Router
logging queue-limit 100
enable password cisco
username ***** privilege 15 password 0 *****
aaa new-model
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
ip subnet-zero
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp key ********* address 38.116.128.50
crypto isakmp client configuration address-pool local VPNClient-Pool
crypto isakmp xauth timeout 15
crypto isakmp client configuration group VPNClients
 key ********* (different from other PSK)
 pool VPNClient-Pool
 acl 100
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
 set transform-set ESP-3DES-SHA
 reverse-route
crypto dynamic-map SDM_DYNMAP_2 1
 set transform-set ESP-3DES-SHA1
 match address 101
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 65534 ipsec-isakmp dynamic SDM_DYNMAP_2
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface FastEthernet0/0
 description Central Internal
 ip address 192.168.100.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface FastEthernet0/1
 description Central External
 ip address 38.116.128.49 255.255.255.240
 ip nat outside
 duplex auto
 speed auto
ip local pool VPNClient-Pool 192.168.1.1 192.168.1.254
ip nat inside source route-map nonat interface FastEthernet0/1 overload
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 permanent
access-list 100 remark SDM_ACL Category=4
access-list 100 permit ip 192.168.100.0 0.0.0.255 any
access-list 101 remark SDM_ACL Category=4
access-list 101 remark IPSec Rule
access-list 101 permit ip 192.168.100.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 110 remark SDM_ACL Category=18
access-list 110 remark IPSec Rule
access-list 110 deny   ip 192.168.100.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 110 deny   ip 192.168.100.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 110 permit ip 192.168.100.0 0.0.0.255 any
access-list 115 remark SDM_ACL Category=16
access-list 115 permit ip 192.168.100.0 0.0.0.255 192.168.6.0 0.0.0.255
route-map nonat permit 10
 match ip address 110
radius-server authorization permit missing Service-Type
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
 logging synchronous
line aux 0
line vty 0 4
 privilege level 15
end
------------------------------------------------------------------------Start
Remote Config
!version 12.2
hostname Remote-Router
memory-size iomem 25
ip subnet-zero
ip audit notify log
 encr 3des
 group 2
crypto isakmp key ********* address 38.116.128.49
crypto map SDM_CMAP_1 1 ipsec-isakmp
 description Tunnel to 38.116.128.49
 set peer 38.116.128.49
 match address 100
 no ip address
 speed auto
interface FastEthernet0/0.2
 description Remote External
 encapsulation dot1Q 2
 ip address 38.116.128.50 255.255.255.240
 ip nat outside
interface FastEthernet0/0.3
 description Remote Internal
 encapsulation dot1Q 3
 ip address 192.168.6.1 255.255.255.0
 ip nat inside
ip nat inside source route-map nonat interface FastEthernet0/0.2
overload
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0.2 permanent
ip http server
access-list 100 remark IPSec Rule
access-list 100 permit ip 192.168.6.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 110 deny   ip 192.168.6.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 110 permit ip 192.168.6.0 0.0.0.255 any
access-list 115 permit ip 192.168.6.0 0.0.0.255 192.168.100.0 0.0.0.255
line con 0
 logging synchronous
line aux 0
line vty 0 4
 privilege level 15
 logging synchronous
 login local
end
Your input is greatly apprieciated,
Jim
Re: Failry simple VPN Lab
Take a llok at these from your remote config:
 match address 100
 ip nat outside
And the n take a look at the headend config ...
You do not have the "set peer" + "Match adress" on the headend crypto map.
Also you should make the habbit of give the IP of your gateway instead of
just say "interface"
You can run into problems with ARP if you do as you do, as the router will
ARP for the gateway each time.
If for some reason, like it is a firewall, the do not reply, you can have
problems.
HTH
Martin Bilgrav
Site Timeline
