Difference between GBIC and Giga Ethernet interface
Threaded View
Hi all,
I will connect 2 switchs catalyst (2950 or 2960) by STP by Giga interface.
For this need, generally, i use GBIC interface and its work fine.
Today, a lot of catalysts are provided with Giga Ethernet interface (RJ45)
like catalyst 2960.
If i use this port (Giga Ethernet interface) to connect the two switchs,
what will be the differences ?
So, i juste need to understand what differences btw Gbic and Giga Ethernet
interface and what is the best choice ?
Thank You very much !!!
Best Regards
Rahan
Re: Difference between GBIC and Giga Ethernet interface
Rahan wrote:
I'm not an expert but I think GBIC enables you to cover a greater distance. If
your link length is less than that
specified for Gigabit Ethernet you can use Gigabit Ethernet.
We're using GBIC to connect 2 switches  located in 2 different buildings. Maybe
we could do the same with Ethernet.
If your switches are quite close each other you don't need to move to GBIC.
Alex.
Ethernet
distance. If your link length is less than that
Maybe we could do the same with Ethernet.
GBIC.
Thanks a lot Alex.
Can someone confirm that distance is the alone difference ?
In technology fibre (Gbic or Mini-Gbic), two cables (fibres) are used. I
think that one is used to transmit and the second for receive data. If it's
true, using Gbic or Mini-Gbic (SFP) can increase bandthwith performance.
i am not sure. i don't know.
Any confirmation ?
Thanks a lot
Best Regards
Rahan
With a "1000BASE-ZX" you'll get up to 70km ...
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet0900aecd8033f885.html
as opposed to 100m with the "1000BASE-T SFP" ...
http://www.cisco.com/application/pdf/en/us/guest/products/ps5455/c1650/cdccont_0900aecd8040bd01.pdf
Other relevent data sheets ...
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheets_list.html
BernieM
1000BaseTX is 1000BaseTX whether on GBIC or not.
However - be aware than not all ports are created equal however I think
that
on your particular platforms that there will be no difference.
On a 4500 for example the Supervisor engine ports each
have a dedicated 1Gbps to the Switch fabric and many
line card ports do not.
Even copper ports nowaday run really clean.
Here is the first one that I looked at:-
  Hardware is Gigabit Ethernet Port,
     8415914730 packets input, 4343581946310 bytes, 0 no buffer
      1389 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
The input erriors are due to congestion since this port
contends for the backplane.
Thanks a lot for yours answers.
So, the connector of SFP port is RJ45 ???!!!
Can you confirm please ?
Rahan
No, SFP is not RJ45. SFP stands for "Small Form Factor". In that SFP port
you could put a fiber or RJ45 gbic in it.
so, when you said "you could put a RJ45", you mean converter Fiber to RJ45 ?
and when you use directly module Fiber, it's a native solution ?
Thanks a lot
Rahan
You can get SPF with 1000baseTx (!) hence , yes is might be a RJ45
Rahan,
When you buy a switch with an SPF /slot/ it is exactly like buying a
switch with a GBIC /slot/.
You cannot connect anything to it /except/ an SPF module
or a GBIC module. These are extra cost items.
In turn the GBIC or SPF allows you to connect a variety
of different physical cable types.
For example -
   RJ45 terminated Cat6 cable
   Appropriately terminated Multi-mode fiber
   Appropriately terminated Single mode fiber
The SPF slot is about the same size as an RJ45 socket
and in a low resolution web image looks a lot like an RJ45
socket but it is not.
The SPF system is like the GBIC system except that the
modules are smaller.
I hope that answers your question. Finally:-))
port
RJ45
Thanks You anybody43 for your answer. It's verry full answer !! :)
Thanks a lot !!
Best Regards
Rahan
Hi Rahan,
SFP is "Small Formfactor Pluggable" GBIC that works very similar to a
full size GBIC, except its much smaller.  When you see SFP, just think
GBIC (but in a physically smaller size). Just like a full size GBIC
you plug in the appropriate SFP module (the actual GBIC) that you wish
to use, either Copper or Fibre, etc.
Cheers..................pk.
Peter from Auckland.
Hi
yes - many has 10/100/1000 RJ45 ports.
That you use another port.
A port is a port - doesnt matter what interfaces it has.
GBIC (older tech) come in many flavors. like fiber, stacking, longrange
fibers, and RJ45-1000baseT
SPF (Newer Tech) comes in not somany flavors, fiber, longrange fiber and
RJ45-10/100/1000 (!)
GBIC and SPF are both names/terms for the connecting interfaces. The port
"in the other end" is just a regular port, like if it were a 10/100/1000.
HTH
Martin
(RJ45)
Ethernet
Thanks a lot Martin !!!
Best Regards
Rahan
To add to this discussion there are four types of gigabit ethernet:
1000baseSX - short wavelength optical max distance about 500m
1000baseLX - long wavelength optical max distance about 500m
Both optical methods can use multimode fiber optics, but only LX can use
single mode. Single mode has a farther max distance, but I am not sure of
the maximum.
1000baseCX - shielded twisted pair copper
1000baseTX - unshielded twisted pair copper. cat5e or cat6 cable required.
enjoy.
Cisco have plenty of documentation about SFPs and GBICs that will answer
Rahan's questions and correct a couple of glaring misconceptions in the
above.  Try starting at
<http://www.cisco.com/en/US/products/ps6577/index.html>.
Sam
Site Timeline
