CVOICE 642-432
Threaded View
Who has done the 642-432 recently? I am using the "actualtest.com" material
and the CVOICE course student guide to prepare for the 642-432 exam. Will I
be fine using these?
Thanks,
Erik
Re: CVOICE 642-432
Hi
I have completed the CVOICE exam 9am this morning,- 893 /1000 (pass
mark is 734/1000)
you will find that if you are using the virtul test engine within the
"actulaltest.com"  642-432 and getting round about 90-95% and using the
.pdf format you will pass the exam, i have had limited experiance
working with IPT and configuring dial-peers....etc just memorising Q&A
round about 220 questions in  the test bank
Note
there is around 60 question 2 drag and drop and 1 simulator.
in the actual test 642-432 have a close look at the simulator -
enable
configure terminal
dial-peer voice 1 pots
destination-pattern 65656575576567????
port 1/0/0
dial-peer voice 2 voip
destination-pattern +9T
session target ipv4:172.x.x.x
that will complete the simulator.
there are also about 10 question that i did not see in the 642-432
actal test document ....some drag and drop questions
hope this helps bud
cheers
James
Erik wrote:
Re: CVOICE 642-432
"i have had limited experiance
round about 220 questions in  the test bank"
--It's pieces of shit like you who are ruining certifications.  Why would
you even take the exam if you have to use a braindump to configure the
simple simulations on this exam?
Rommon>
Re: CVOICE 642-432
How can you say that when you dont even know me you DICKHEAD
when you are working in the IT Industry .....like myself, once you have
setup and configured  dial-peers there is no need to change them
provided they are done correctly!
configuring dial-peers is not my day to day job.- I posted the notes on
the exam to help peolple like you who are looking to pass the CVOICE
exam.
"It's pieces of shit like you who are ruining certifications"
please note:
to learn you must start somewhere and I have found that you are more
likely to pass any exam by reviewing the test bank than reading a 1000
page bible.- not everyone if lucky enough to have the practical
experiance so it is a good work around.
especialy when you are working MON-FRI and there is kids at home! who
just love to interupt you when you are studying .....you are defo a
single minded prick with no wife and kids - hence your judgment.....and
poss a little jelous !:-P
for the people like me the Cisco certifications can be passed provided
you put in the effort and once you gain your Cert you will learn as you
will be working with routers, switches, etc...daily after all it is
human nature to learn each day! and one day the penny will fall
and to answer your question -
Why would you even take the exam if you have to use a braindump to
configure the
A - to renew my CCNA + CCDA and target CCVP Certification you do know
that passing any 642-x exam will renew your assosiate level
certification....don't you?
cheerz
James
CCNA, CCDA
CVOICE
Re: CVOICE 642-432
1. Your comments make no sense.  Cheating is cheating.
2.  I do have a wife and kids at home.
3. I am a WAN engineer for a Cisco Partner and didn't need braindumps to
pass an exam like CVOICE.
You even admit that you have limited experience IPT.  Why not actually learn
how to deploy a Cisco IPT solution and then get certified instead of
memorizing a bunch of exam questions.  Let me guess...I bet your an MCSE
also.....
and most cisco engineers who do this everyday for a living would probably
agree with me, your are a piece of shit for cheating.
Rommon>
Re: CVOICE 642-432
Maybe you will feed differently if your boss tells you, you have to make it
to CCIE by then end of this year.
Re: CVOICE 642-432
Um...yeah....good luck with that CCIE.
Re: CVOICE 642-432
Sounds like your boss and you need to find a job elsewhere - in a
different industry entirely.  Fast food perhaps?  You can probably pass
their tests easily.
Re: CVOICE 642-432
Passed the exam this afternoon 887/1000.
Thanks,
Erik
Site Timeline
