CCNA - ICND question - help
Threaded View
I need help on a question from the CCNA-ICND test.
I didn't pass for a second time, and got the exact same score of
837/1000.  849 is a pass.
I believe this problem is what I've been getting wrong:
2 things needed:
- correct addressing on RtrA
- correct LAN config on RtrB
Server & Host Y need to be able to communicate.
Connections:
Host consoled to RtrA
RtrA s0/0 connected to RtrB s0/0
RtrA fa0/0 connected to Sw1
Sw1 connected to Server 10.1.1.148/24
RtrB fa0/0 connected to Sw2
Sw2 connected to Host Y 192.168.3.28/24
Config's:
RtrA:
s0/0
192.168.2.5/30
fa0/0
10.1.1.147/24
rip 10.0.0.0
rip 192.168.2.0
RtrB:
192.168.2.6/30
fa0/0
192.168.3.27/24
shut
rip 192.168.2.0
rip 192.168.3.0
Of course I enable RtrB fa0/0, which is half of the answer.
I can't figure out any problems with the addressing on RtrA.
Can someone help me?  I'd really appreciate it.  Thanks
Re: CCNA - ICND question - help
RtrA:
s0/0
192.168.10.5/24
fa0/0
10.1.1.147/24
rip 10.0.0.0
rip 192.168.2.0
RtrB:
192.168.10.6/24
fa0/0
192.168.3.27/24
shut
rip 192.168.2.0
rip 192.168.3.0
Thanks Klutz, but would you mind explaining why you'd change the
serial int's from:
192.168.2.5/30
192.168.2.6/30
to
192.168.10.5/24
192.168.10.6/24 ... ?
I understand RIPv1 is classful, but isn't subnetting to /30 allowed ?
This isn't VLSM, correct?
I know it isn't VLSM, but RIP version1 don't announce the subnet mask.
So,on RTA,192.168.2.5/30 and 192.168.2.0/24 are in the same network
.Router's interface should connect different network. You announce the
network 192.168.2.0 on fa0/0 of RTA,how it determine the packet's export?
s0/0 or fa0/0?
Where are you seeing that?
The original config is this (rewritten in IOS format):
RtrA
int s0/0
 ip address 192.168.2.5 255.255.255.252
int fa0/0
 ip address 10.1.1.147 255.255.255.0
router rip
 network 10.0.0.0
 network 192.168.2.0
RtrB
int s0/0
 ip address 192.168.2.6 255.255.255.252
int fa0/0
 ip address 192.168.3.27 255.255.255.0
 shutdown
router rip
 network 192.168.2.0
 network 192.168.3.0
Server (10.1.1.148/24) connected to RtrA's LAN
Host Y (192.168.3.28/24) connected to RtrB's LAN
So, other than doing "no shutdown" on RtrB's fa0/0 and adding "version 2" to
both rip configs, I don't see what else can be wrong here.
OK, sorry just realized I still had my home lab available -- too much
studying without it I guess.
I punched the config in and the addressing works fine.
So when the Sim asks to fix/correct the addressing on RtrA, what else
could that entail?  Anyone have any ideas?
Has anyone taken the ICND recently?  Thanks again
On Mon, 16 Jul 2007 23:13:36 -0700
How do you know you didn't get this one right?
Did you ping to test?  All I could see was whether or not you ensured rip was
at v2 or used another routing protocol, as it wouldn't work with v1.
During the Sim, I was able to ping both the Server and HostY from both
routers.
At home, I only used Ripv1, so addressing seems to work as is.
I know I got it wrong because the Sim asked for 2 things and I could
only do 1.
that's strange, i already replied to this yesterday.
anyway, i too put this into my home lab (sorry, i forgot i had it --
too much studying).  the addressing for rip v1 works as is.
so, now i don't know what the sim wants when it says to correct the
addressing on rtr a.  it's supposed to be straight-forward, but this
one isn't.
anyone take the icnd recently?
Site Timeline
