Wireless Protocol Implement - Which Experimental Devices?! Dev. Tools?
Dec 03, 2007 0 Replies
Dear All
I just want to implement some sort of Protocol as part of Wireless protocol suites, actually a MAC Layer protocol for 802.11. I need to change the Wireless Adapter's default behavior, like dropping bad CRC packets etc.
In my point of view steps should consist of some sort of Firmware modification and Driver development, is that correct?
And the question is, How to do that? Are there any well-known device for experimental purposes? or a suitable one that is modifiable? or Some kind of Development Kit?
I don't know where to look for.
Looking forward to you kind replies, and opinion
Best Regards
