weak/marginal connection, any settings that can make it more reliable?
Oct 31, 2006 1 Replies
John Navas
Your only real hope is a better antenna and/or better location, and it's going to be hard to beat your Hawking 15dBi Corner Antenna by enough to matter without changing the location. How about: 1. Wired Ethernet connection to a wired Ethernet bridge (possibly with Power over…
Trying to connect with a wifi and getting a very weak signal. Already did the directional antenna thing, helps but not quite enough. Are there any settings in the wifi manager box I can change to trade say connection speed for better reliability of connection? I'm already at the high power setting. Reducing connection speed doesn't seem to help or hurt, so I left it at "auto". It's a Hawking desk top card connected to a Hawking corner reflector antenna with extra reflectors added to it.
On Tue, 31 Oct 2006 18:51:22 GMT, robert casey wrote in :
  1. Wired Ethernet connection to a wired Ethernet bridge (possibly with Power over Ethernet) in some other location?
  2. Wireless repeater in some other location?
