MN-700 Base Station - adding a signal booster or antenna
Mar 16, 2005 0 Replies
In my home network, I have a few dead and weak spots on my wireless network, and I wanted to add a booster antenna or signal booster such as a couple offered by Hawking. The problem is, unlike some of the other wireless base stations, this antenna seems to be permanently attached and does not unscrew. Is there workaround for this, or will the antenna come off? Failing that, if I take it apart, is it easy to remove the old antenna and solder a new jack on that would accept a new antenna?
