[image:
*Skype Phone: RS-101*- High quality Voice-over-IP calls By using powerful Digital Signal Processor, the USB phone is able to deliver an echo free, full duplex audio through the Internet. No external power required The power of the USB phone is provided by the USB port of your PC, therefore, you do not need to have an additional power adapter for your USB VoIP devices. Drivers support and upgrades from Microsoft The drivers of the USB VoIP Series are provided by Microsoft Windows, thus no additional drivers are required. Drivers are currently available in Microsoft Windows 98/98SE/ME, and Windows 2000. Plug-and-Play, Grab-and-Go With its compact size and USB interface, the USB phone is your ultimate travel companion. You can take it with you wherever you go. Just plug in any computer with an available USB port and an Internet connection, along with voice chat or ITSP (Internet Telephony Service Provider, such as Net2Phone, Dialpad, Mediaring and PC-Telephone.) applications on it, and you are ready to make long distance calls to any phone in the world or global call to any PC. PC to PC, and PC to Phone dialing capabilities Full duplex audio, echo cancellation Microsoft interface for USB audio devices Compatible With all popular VoIP soft dialers Supports Windows and Linux Rings on an incoming call Easy integration into your custom applications with the FREE API [image:
Phone:PB-35
1 RJ45 port: PB-351
2 RJ45 ports:PB-352 SIP, H.323 V4,MGCP,Net2phone private protocol
Audio codec G.711,G.723,G.729
DHCP support for LAN or Cable modem
PPPoE support for ADSL or Cable modem
Set phone by HTTP web browser (IE6.0) or Telnet
Upgrade by FTP
VAD(Voice active detect)
CNG (Comfort noise generation)
Dynamic voice jitter buffer
G.168/165 compliant 16ms echo cancellation
Tone generation and Local DTMF re-generation according with ITU-T
E.164 dial plan and customized dial rules
100 entries for quick dial
80 entries each for missed calls, answered calls and dialed calls
Adjustable volume for both handset and speaker
Voice prompt
Hotline
_*Alex_Kong_
China_Roby_Technology_Co.,_Ltd. __Email: snipped-for-privacy@chinaroby.com __Web__:_www.chinaroby.com __Skype:_alex_kong2005 __Tel__:_+86-755-83843088 __Fax__:_+86-755-83843088*_
IP Phone:PY-60
1 RJ45 port: PY-601
2 RJ45 ports: PY-602
[image:
] Supports SIP, IAX2,H.323,Net2phone Supports Asterisk Audio codec G.711,G.723,G.729
Upgrade by FTP
Voice prompt
Hotline
_*Alex_Kong_
[image:
*Gateway_with_1_FXS_ports:GN-06*_ Support SIP2.0,TCP/IP,RTP/RTCP,HTTP,ICMP,ARP,DHCP,NTP/SNTP,TETP protocols Support STUN and symmetric RTP for NAT Interoperable with various 3rd party SIP end user device,Proxy/Registrar/Server, and gateway products. Advanced 32bit embed MCU + DSP technology to ensure superior audio quality. Advanced adaptive jitter buffer control, packet delay and loss concealment technology Support popular vocoders including G.723, G.729A/B, G.711(a-law and u-law), G.726 Support standard voice feature such as Caller ID Display or Block, Call Waiting, Hold, Transfer, Forward, in-band and out-of-band DTMF, Dial Plans Support Silence Suppression, VAD(Voice Activity Detection), CNG(Comfort NoiseGeneration), Line Echo Cancellation(G.168), and AGC(Automatic Gain Control)
_*Alex_Kong_
