Inexpensive Home Automation in Australia
Dec 28, 2005 2 Replies
Inexpensive Home Automation in Australia open original image
Looking around the 'net, it seems that it is ridiculously expensive and difficult to do home-automation in Australia. As we use 240v/50Hz rather than 110v/60Hz, we can't the US stuff .. which is a pity as it is *much* cheaper.
That said, does anyone know anything about HA that can help me out sourcing equipment at good prices.
Here's what I want: Lighting controllers for four groups of dichroic 'halogens' hidden in the ceiling or behind the switch plate is good .. my house is being built at the moment, but I wonder if the halogen groups will be like our office: power outlets in the ceilings into which the transformers are plugged .. if so, I guess an appliance controller might work
Lighting controllers for six incandescent lights
Hi Rick
Although not as cheap as x10 ....I would suggest using CBUS as Dave has mentioned in his post.....If your friendly with your sparks he should get you the CBUS kit at trade prices.........Have a quick look at my site for the CBUS info....I have my pirs connected to my alarm system "Genesis"an Oz panel and i pass pir status to CBUS + Homevision (my ha controller) via relays..... For pc based HA control have a look at xPL....I believe theres a Linux version and also a CBUS Plugin so you can control cbus via other apps etc....
HTH Frank
