Was trying to use through web remote desktop home computer in New York from remote location.
Home computer has Windows XP Pro SP2 with IIS and web remote desktop installed. Computer is connected through Verizon DSL and uses Westell
6100 modem/router. No luck. Did not have access to the needed for web remote desktop page on my computer (it seems access tcweb/Default.htm).So, turned off local firewall, went to Westell 6100 modem and turned off its firewall and directed to my computer all ports 1-65535, created small html test page under IIS and set security for access from outside that html page. It works through localhost OK. But using current IP address of my computer I can not access a test html page from outside of my computer:
Internet Explorer cannot display the webpage
Most likely causes: You are not connected to the Internet. The website is encountering problems. There might be a typing error in the address.
Tried to use different ports through IIS port setting and using that port in server:port web page address combination with several ports: 80 (standard and it is announced as blocked by Verizon), 1, 25, 8080,
10000, 65535 etc.The same result.
Called Verizon. They deny outright that Verizon blocks all inbound ports. They only confirmed blocking 80.
Have anybody found solution to this? I saw several mentioning of "Verizon dsl blocks all inbound ports" in earlier posts but without positive or negative conclusion.
Or do we need to leave Verizon in droves for more friendly service?
Thanks, Val
