Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Mark on September 18, 2004, 2:26 pm
Please log in for more thread options verizon DSL with the westell 2200 DSL modem. So I got the kit, but I've found out that the install process seems to require you to use Windows only software to get the username/passwd to log into the network. I had been assuming to that point that the software was for the MSN extras stuff that I wasn't going to use anyway. Since I only have linux I can't run that and without the password/username I can't get on. How could I work around this? Some people say you can call them and say you are using a router and they will give you a username password on the phone? I didn't get that because I'd think they'd tell you to plug into the modem directly from the pc, do the setup then swap the cable back to the router and the router to the modem. Any ideas? Mark | ||||||||||||||||||||||||||||
Posted by John Dearing on September 18, 2004, 8:48 pm
Please log in for more thread options Is there *any* way to beg/borrow/steal a Windows box to use temporarily just to get you past the initial setup?? Otherwise, you're looking at making a call to tech support to walk you through getting a username/password. You need the username/password only if you are in a former Bell Atlantic area that uses PPPoE to authenticate. Some former GTE areas are starting to go to PPPoE but most are DHCP. I still think the most expeditious route woule be to borrow a Windows box and then return it once you are finished. Good luck!! John -- John Dearing A+, Network+ | ||||||||||||||||||||||||||||
Posted by Mark on September 18, 2004, 9:07 pm
Please log in for more thread options John Dearing wrote:
> Mark wrote:
> >> I read many positive results from linux users using
>> verizon DSL with the westell 2200 DSL modem. >> >> So I got the kit, but I've found out that the >> install process seems to require you to use >> Windows only software to get the username/passwd >> to log into the network. I had been assuming to >> that point that the software was for the MSN >> extras stuff that I wasn't going to use anyway. >> >> Since I only have linux >> I can't run that and without the password/username >> I can't get on. How could I work around this? >> Some people say you can call them and say >> you are using a router and they will give you >> a username password on the phone? I didn't get >> that because I'd think they'd tell you to >> plug into the modem directly from the pc, do >> the setup then swap the cable back to the router >> and the router to the modem. >
> > Is there *any* way to beg/borrow/steal a Windows box to use temporarily > just to get you past the initial setup?? > > Otherwise, you're looking at making a call to tech support to walk you > through getting a username/password. You need the username/password only > if you are in a former Bell Atlantic area that uses PPPoE to > authenticate. Some former GTE areas are starting to go to PPPoE but most > are DHCP. > > I still think the most expeditious route woule be to borrow a Windows > box and then return it once you are finished. > > Good luck!! > > John > -- > John Dearing > A+, Network+ John, btw, for the router I'll be using Ipcop 1.4 on a standalone pc (home page http://www.ipcop.org) if that changes anything. It supports PPPoE, DHCP, all of it. Mark | ||||||||||||||||||||||||||||
Posted by John P. Dearing on September 19, 2004, 2:09 am
Please log in for more thread options Mark wrote:
-=[ deletia to save space]=- > John, btw, for the router I'll be using Ipcop 1.4 on a standalone pc
> (home page http://www.ipcop.org) > if that changes anything. It supports PPPoE, DHCP, all of it. The Westell 2200 can operate in one of two modes. The first, "router" mode has the device operate much like a small broadband router (think Linksys, Netgear, etc...). The 2200 has built-in NAT and a PPPoE shim that will hold your username/password for authentication. It just doesn't have the built-in switch/hub, you have to add that yourself. The second mode is called Bridge mode. In this mode the 2200 operates as a simple DSL modem, that's all, nothing more. My previous recommendation to use a Windows box to do the account setup and then you can decide how you'll configure the Westell (router vs bridge) for your Linux network. My own preference is to have an appliance do the router/NAT work and save the PC's for, well, PC work. Unless your doing this as an educational exercise. John -- John P. Dearing A+, Network+ To reply: Just drop "YOURPANTS" in my address! 8-) | ||||||||||||||||||||||||||||
Posted by Mark on September 21, 2004, 7:18 am
Please log in for more thread options John P. Dearing wrote:
> Mark wrote:
> > -=[ deletia to save space]=- > >> John, btw, for the router I'll be using Ipcop 1.4 on a standalone pc
>> (home page http://www.ipcop.org) >> if that changes anything. It supports PPPoE, DHCP, all of it. >
> > The Westell 2200 can operate in one of two modes. The first, "router" > mode has the device operate much like a small broadband router (think > Linksys, Netgear, etc...). The 2200 has built-in NAT and a PPPoE shim > that will hold your username/password for authentication. It just > doesn't have the built-in switch/hub, you have to add that yourself. > > The second mode is called Bridge mode. In this mode the 2200 operates as > a simple DSL modem, that's all, nothing more. > > My previous recommendation to use a Windows box to do the account setup > and then you can decide how you'll configure the Westell (router vs > bridge) for your Linux network. > > My own preference is to have an appliance do the router/NAT work and > save the PC's for, well, PC work. Unless your doing this as an > educational exercise. > > John > -- > John P. Dearing > A+, Network+ > To reply: Just drop "YOURPANTS" in my address! 8-) There's another reason besides the educational one, the standalone pc does a better more flexible job of it than the typical appliance. Logging is better, ipcop uses snort.org to actually tell you what all the firewall/ids events mean and rate the severities. Also with ipcop you have built-in local squid proxying, you can't do that easily with a hardware appliance. Plus since it's squid, squid supports ad filtering. (using squid_redirect) Plus I was already using the ipcop box and had it all setup so going to the appliance would mean reinventing the wheel and setting up all the rules in the appliance that I already had working in ipcop. Mark | ||||||||||||||||||||||||||||
| Similar Threads | Posted |
| trying to use Verizon DSL with linux | September 18, 2004, 2:26 pm |
| How to set up usb adsl modem in Linux? | July 21, 2004, 5:26 am |
| PPPoE Server in Linux . | September 5, 2005, 7:31 pm |
| Hosting a web site on a home Linux box | March 18, 2007, 11:40 am |
| news.verizon.net | July 28, 2004, 12:27 pm |
| news.verizon.net | August 4, 2004, 5:19 am |
| Verizon DSL with router | August 26, 2004, 10:12 pm |
| Some help with new Verizon DSL and existing AOL... | October 15, 2004, 2:24 pm |
| Verizon DSL password | November 4, 2004, 3:24 pm |
| Verizon Naked DSL? | February 27, 2005, 3:34 pm |
| Verizon DSL in MD problems | March 14, 2005, 7:41 am |
| Verizon Newsgroups | March 20, 2005, 12:49 pm |
| Verizon can't see my 82557 NIC | September 3, 2005, 7:15 am |
| New Verizon DSL rate | September 29, 2005, 9:23 pm |
| verizon dsl availability, used to have it, now vz says dsl not available | January 15, 2006, 4:32 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
